head gasket replacement timing?
Had my head milled out it was warped 004.Getting ready to put back together,Do i have to do anything special on timing?I know the marks have to be lined up on cam and crank but does 1 revolution complete the cycle to make sure i am tdc on compression stroke on number 1 cylinder?I guess my question is as long as the timing marks are lined up correctly am i good to go?
Re: head gasket replacement timing?
Set up crank on TDC mark
Set up the cam and gear to correct position before you install the head
alex_nyc
27
Jun 16, 2019 08:27 PM
Wild Cranker
25
Feb 28, 2016 09:08 AM
Conda Hivic
Jan 17, 2016 01:33 PM
