Slow Acceleration Low Rpm ( manuel )
Old Aug 7, 2016
  #31
Wankenstein's Avatar
Re: Slow Acceleration Low Rpm ( manuel )
OP: This site has a lot of good testing write-ups for 6th gens and other models: http://troubleshootmyvehicle.com/hon...-of-articles-1
Old Aug 7, 2016
  #32
Originally Posted by ezone
It's definitely necessary to know all of those tests when dealing with 20 year old Ford products LOL
Fixed
Or
Repaired
Daily
Except for their trucks which are solid.
I performed the spark plug wire leak test before work this morning and no visible arcing noticed.
Old Aug 7, 2016
  #33
Originally Posted by turd_ferguson
Fixed
Or
Repaired
Daily
Fu*ked
Over
Rebuilt
Dodge
Old Aug 8, 2016
  #34
PsychicExperien's Avatar
PsychicExperien is an unknown quantity at this point
Fu*ked
Over
Rebuilt
Dodge
I removed my wires just like in the video , when i was holding it in the air it was working normal ( no sparks ) but when i put the sides of it near the engine it kept doing the ticking sound , I'm gonna change them and give you update
Old Aug 8, 2016
  #35
Sparks coming out of the very end of the wire is correct, thats where the sparkplug has to receive it.
Sparks through the side is wrong
Old Aug 9, 2016
  #36
Don't throw parts at it... as Ezone said the ticking when the spark plug wire is first lifted off of the spark plug or when held against ground is normal, as long as it's not arcing from the sides of the spark plug wire. If the engine is using NGK or Prestolite wires it's uncommon for them to be the weak or failed source of ignition.
The ticking sound is supposed to be rythmic due to the rotation of the distributor and rotor delivering spark to the cap points and SP wires at repetative timed intervals.
Have you performed a dry and wet compression test on it yet?
Fuel injector testing: http://troubleshootmyvehicle.com/hon...el-injectors-1
Have you performed a valve lash adjustment?
As an apprentice mechanic these should all be test and maintanence that you either have or will learn to do.
Old Aug 10, 2016
  #37
I got ngk wires at the scrap and you feel the missfire a bit less ( shakes less ) i got a timing belt kit because the timing belt is still original , when im gonna change it , I will readjust the valves
Old Aug 11, 2016
  #38
The TB replacemnt and valve adjustment is a good move however, at least do a dry and wet compression test first to rule out a possible leaky cylinder. Also, if you have the means a leak-down test should help isolate a possible valve(s) leak. My point is that if there is a leaking cylinder or valve causing a misfire and/or the issue your engine has are you sure you want to invest more money into it (i.e. timing belt, waterpump, tensioner)?
Old Aug 11, 2016
  #39
Yes you are right and i was going to do the timing belt because i got it as a gift from a friend
Old Aug 14, 2016
  #40
The problem was the timing , it works alot better now
Old Aug 16, 2016
  #41
Glad you got it sorted out. the belt was probably of a tooth.
Now you can the most out of the available 106 hp.
OptimisticWay
Jan 3, 2016 07:54 AM
Munzy
Engine DIY
Oct 31, 2015 08:49 PM
carid
Oct 30, 2015 09:20 AM
trv020
Oct 28, 2015 10:37 PM
jrbucklin
Oct 26, 2015 08:38 PM
