i screwed up
Old Feb 14, 2016
lequea23's Avatar
lequea23 is an unknown quantity at this point
i screwed up
ok I screwed up over a year ago I bought and installed a new motor in my 96 civic which had the d16y7.my d16 had a bad cylinder and smoked bad. so I did some research and thought I had the best fit and for the most part a plug and play simple install.what I found was a zc block not a zcy# whatever just straight zc which from the research that I had done had more hp then the d16 its supposed to be the 20 year anniversary of the d series block . I got it with a partial wiring harness and ecu the ecu code is p76 and i need a jumper from the p2e harness that's in my car to the p76 ecu the motor need to make it run right does any one know where to get the correct ecu jumper ive had ppl say they had it and it wasn't right
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Hollywoodsnake
Sep 20, 2015 12:58 PM
Dave Brabant
Sep 12, 2015 08:39 PM
EM2661
Sep 11, 2015 06:01 PM
Boosted
Nov 21, 2003 11:03 PM
