Distributor between y8 and y7??
Old Dec 29, 2015
tattedlariat's Avatar
tattedlariat is an unknown quantity at this point
Okay so i've got a 2000 civic, motor went bad. its an EJ8, which means it should have a d16y8, right? Except its a D16y7. Blah blah blah, i bought a y8.
Got the motor in, everythings going decently smooth, except the distributor. On the harness for the car it has a different plug than the one on the new motor. I've got a new dist for the y7, can i just throw that on the y8? Or do i need to start all over with a d16y7?
Old Dec 31, 2015
BK201's Avatar
BK201 is an unknown quantity at this point
Re: Distributor between y8 and y7??
the y7 in the earlier years had a TEC and a Hitachi distributor in them
and the 99 and 00 both run the TEC for the y7 and y8
98 and pre they had the two choices for both y7 and y8
so if its a pre 98 y7 it might be running the Hitachi distributor on the broken engine in the car
which if you bought a 99 or 2000 y8 or you bought a y8 of 96-98 with a TEC distributor you would be looking at a different plug
Old Dec 31, 2015
BK201's Avatar
Hitachi
TEC
*Pictures from oreillyauto.com and Richporter Technology*
Old Dec 31, 2015
So can i just swap the distributor from TEC to the hitachi?
Old Dec 31, 2015
BK201's Avatar
yup
if thats the only problem
you might be able to trade someone in your same situation or junk yard it
hit or miss on the yard but they do like 30 day warranty
