98 Civic EX hesitation accelerating?
Old 06-19-2015
Kyrian's Avatar
Kyrian is an unknown quantity at this point
I recently bought a 98 Honda Civic EX about three months ago. It was running fine for the first two weeks. Then it started having problems where the acceleration would start hesitating and then not work at all and when it did I could only go between 1-10mph. It would mainly only start acting up when I would stop at a traffic light or turn my car off to get gas or something. I considered the caliper was sticking but the brakes look new. And not to mention my ABS light is always on, from the time I first start my car. But I assume the ABS has nothing to do with my power loss. There for a while the engine light would even come on. It hasn't come on anymore since I did some work to my car though. I did a computer scan and it pulled the codes P0730, P0700, P0113. Two were transmission codes.
So I fixed all the oil leaks when I first got my car by buying all new gaskets for my solenoids, valve cover, and distributor. I got a new timing belt, water pump and so on. I got my transmission rebuilt. I got new spark plugs. I got a new oil filter and transmission filter. I changed the oil and transmission fluid. I got a new torque converter.
I'm running out of ideas of what could be causing my acceleration problem?
Maybe the cat is clogged up or the idle air control valve is bad? I'm not too sure what is going on here. If someone could help me out that'd be awesome.
I do know for a fact that my distributor cap and rotor has some scratches on the inside because someone did not put it on right. I plan on getting a new one but I don't think that would necessarily cause the huge amount of power loss.
The engine seems fine though and I don't see any signs of vacuum leaks or anything of that sort.
I'm becoming quite hopeless because I can't even drive it 5 miles up the road. It loses power anytime I try to drive it.
Old 06-20-2015
Prelude Owner
GolNat's Avatar
Re: 98 Civic EX hesitation accelerating?
Get a new cap and rotor first. You need fuel, air and spark to make the engine run, if any of these are off it won't run correctly.
IACV could be the culprit, you can remove it and clean it.
Old 06-26-2015
Wankenstein's Avatar
Sounds like a spark issue and likely an ICM and/or coil within the distributor is weak or failed...but may have not thrown a CEL code. RonJ to the rescue..he's the Ezone of HT :http://honda-tech.com/honda-civic-de...blems-2919450/
Test first before buying new parts.
ChristinaVHH
05-10-2015 03:51 PM
civic_gt
04-19-2015 08:15 AM
CascadiaBlue
04-18-2015 09:13 AM
CivicVoz
04-16-2015 08:07 PM
dooner24
04-14-2015 07:51 PM
Quick Reply: 98 Civic EX hesitation accelerating?
