leak in trunk
Old Jun 2, 2015
fignewton's Avatar
fignewton is an unknown quantity at this point
leak in trunk
I have a 97 civic coupe ex and I've somewhat found where the leak is coming from, but not really. Its dripping from a panel that i can't see. Any clue as to what is clue as to what is causing it based on its location? The panel its leaking down is covering where the leak is really coming from so i can't really see exactly where its leaking from
Old Jun 3, 2015
GolNat's Avatar
Prelude Owner
Re: leak in trunk
Your pics don't work.
Old Jun 4, 2015
Reverb2005's Avatar
Reverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of light
Re: leak in trunk
Right click - open in new tab worked for me....
Well, either you have a hole in the side of your trunk, OR...
What about that little white connector? Looks like something is dripping down that? (Bottom center). Or is that just underspray?
Just to the left of the right trunk arm.... is that rust on the weather-stripping?
Leaking through #4? Can't tell if it is an external seal?....
Old Jun 4, 2015
Re: leak in trunk
I'm thinking the drip hanging off the wire harness is the leak, so it's coming in somewhere up high.
I see what might be rust under the edge of the trunklid seal.
Might be a drip hiding in the small gap where a couple of those panels overlap. Top pic, just above the hinge.
Back window leaking? Body rot?
Get the areas completely dry.
I like to cover everything in white powder. The powder can help show the paths of the leakage.
Bath talc, foot spray, Right Guard could work, they are all powders.
Pick one that smells good LOL
Set it all up.
Open up the back seat and crawl in the trunk, close the lid.
Have a helper garden hose the car while you watch for the leaks from inside the trunk.
cukaracha
30
Jul 26, 2015 12:01 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
hoofboy
Jul 17, 2015 04:27 PM
Kyles24
Jul 16, 2015 10:14 PM
Causemo
Jul 5, 2015 06:42 AM
