Intermittent no start
Old May 6, 2015
jetcare101's Avatar
jetcare101 is an unknown quantity at this point
98 Civic LX
replaced main relay recently for no start issue. Car ran great for a month or so. While driving, check engine light somes on. Get it home to garage and as I suspected, not start until it sits for 10+ minutes. Car finally starts roughly and smooths out, check engine light is out now and starting normally.
I can hear the fuel pump prime and the main relay click and turn engine light out. Everything seems normal now.
295K miles. I inherited this car probably for this reason. Not my everyday driver. New distributor, plugs, wires by previous owner.
Old May 6, 2015
Re: Intermittent no start
And the code is.....?
Old May 6, 2015
jetcare101's Avatar
No engine light. No code?
I assume it doesn't give history......
Old May 6, 2015
Check for codes anyway.
It has a memory.
Most fault info is stored for a period of time even though the light went out.
Length of time stored may depend on the fault code.
Battery disconnect will erase stored info.
Old May 8, 2015
jetcare101's Avatar
Code is P0118
295k
water pump, belt, coolant changed at 293k
light comes on after driving 1/2 mile today, came home shut it down, light out. starts normally.
Temp sensor under the distributor is not leaking, wire is solid.
Old May 8, 2015
Code is P0118
295k
I'd probably replace the sensor anyway.
You have two temperature sensors under the distributor. One is for the gauge, the other is for the computer. Make sure you replace the sensor for the computer. Two wires on it.
Old May 8, 2015
jetcare101's Avatar
I was wondering about the two sensors there.
Thanks.
ywgflyer
May 15, 2015 05:05 PM
ttharper
May 11, 2015 07:27 PM
black2k1vtec
Dec 6, 2001 09:49 PM
OoSiLvErCiViCoO
Nov 14, 2001 11:35 AM
OoSiLvErCiViCoO
Nov 14, 2001 06:21 AM
