Help! Reading Transmission dipstick. Trans level?? PICS
Old Mar 23, 2015
bighonda's Avatar
bighonda is an unknown quantity at this point
I am having difficulty reading the transmission dipstick level.
Does it indicate the level by the thin film or the dense area of trans fluid?
Extra info: I have a transmission leak, just droplets on the bottom of trans at the moment. Will fix later.
I checked the dipstick at operating temperature with the engine off. On a level surface. Wiped it the first time and subsequent times and this is the 4th check in a row. I took the dipstick out trying not to touch the sides of the transmission.
ID:	87572   Click image for larger version
ID:	87573   Click image for larger version
ID:	87574   Click image for larger version
ID:	87575   Click image for larger version
Last edited by bighonda; Mar 23, 2015 at 03:27 PM. Reason: Add info: I have a Honda civic 2000 ex.
Old Mar 23, 2015
mikey1's Avatar
Re: Help! Reading Transmission dipstick. Trans level?? PICS
tranny warm, shut engine off, level surface/ground
remove dipstick, wipe it off, re-insert, remove dipstick and read level,
always keep the dipstick pointed to the ground when reading the level, this way the fluid can not run up and give you a false higher reading,
assuming you did all of these things correctly, the level on your dipstick seems way too high,
nice sandals by the way
Old Mar 25, 2015
emich's Avatar
emich is an unknown quantity at this point
I am envy about the weather in your area.
As long you see a fluid between the lines you are fine.
Old Mar 25, 2015
If you dried the stick, then stuff it in and pull it out: Wherever the highest place you find wetness on the dipstick, is the level of the fluid.
If you see the wet line in the same place after trying this 3 or 4 times in a row, it's pretty safe to assume that's the actual level inside.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
mattdoc
Mar 14, 2017 12:10 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
supercivic01
South
Nov 30, 2001 11:27 AM
ImmortalEX
Nov 8, 2001 09:52 PM
