Power window switch?
Old Feb 28, 2015
catdaddybaycali's Avatar
catdaddybaycali is an unknown quantity at this point
Bit of a puzzler, this. I have a 2000 Honda Civic LX 4D. My passenger side front power window sometimes works and sometimes doesn't, whether you use the master switch on the driver's side or the switch on the passenger side. The dealer wants $130 to run an electrical system diagnostic. I'm thinking it's probably the passenger side switch, but I know nearly nothing about electrical systems. I found a front passenger side switch on ebay for $30. Do you think it's worth buying and trying the switch, or should I pay for the diagnostic? Any input would be greatly appreciated. Thanks.
Last edited by catdaddybaycali; Feb 28, 2015 at 06:13 PM. Reason: Posted multiple times
Old Feb 28, 2015
Re: Power window switch?
Last edited by catdaddybaycali; 2 Hours Ago at 06:13 PM. Reason: Posted multiple times
Erased multiple posts!
Be aware the cars are well known for breaking the wires in the door jamb where they flex every time the door is opened.
Get it to quit, then hold the switch on while you slowly open each front door. If it starts working then you have wire problems.
Try a window switch out of the rear door instead.
Old Mar 4, 2015
Thanks! This was the exact advice I needed.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
Cypher
Dec 15, 2001 07:25 PM
mwwhonda
Nov 7, 2001 07:24 PM
