2000 civic trouble shifting 1st gear and shakes from stop. (only when warm)
Old Jan 18, 2015
hilyas's Avatar
hilyas is an unknown quantity at this point
Hello experts,
I have a 2000 civic, 83000 miles, automatic trans. It runs well until it warms up (after about 20-25 min of actual driving).
Symptoms when moving from a stop:
- if I press hard on the has, car shakes and has trouble shifting 1st gear when i
- if i let it move for a bit a press slowly, it usually shifts.
- these last 2 symptoms are worse if I am on a hill.
- if i am on a hill the car (at a red light) the car starts moving backward if don't press the brakes.
- sometimes i hear a grinding noise if i go from reverse to drive.
- other gear seems good.
- it gave me a code before that mentioned "solenoid", "low fluid" and something else i don't remember. Unfortunately the check engine light is not on now because the battery was dead for a while.
I checked the fluid, it's not low. Why is it doing it only after driving for a while? Any help will be appreciated!
Best.
Old Jan 19, 2015
Poopies's Avatar
Super Moderator
Re: 2000 civic trouble shifting 1st gear and shakes from stop. (only when warm)
83k miles? Wow, that's hella low! Have you ever changed the tranny fluid?
rcolosi
Apr 29, 2015 07:48 PM
Richkid23
Apr 19, 2015 12:53 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
silvervtec01
Nov 4, 2001 06:56 PM
