96 Civic
Re: 96 Civic
Got an EGR valve? Disconnect it and test drive it.
Try disconnecting the primary O2 sensor and test drive it.
Maybe monitor TPS voltage (among all the other things) on a scanner while the problem is acting up?
Too many possibilities for your symptom (as described) here, need a ton more info.
Throw away any Bosch Platinum plugs, get the correct NGK!
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
