97 Civic DX HB crank no start when warm - Tried everything
So I finally got around to testing the sensor wires for voltage (Christmas and rain kept me from doing so). I did a base test on my battery and got 12.44v. I then connected them to the sensor plug and got two different readings. When connecting them one way I got a reading of 11.96v and then reversed the leads and got a fluctuating voltage around 12.11 volts. I know this is bad and must have a short or open circuit but I'm no electrician so any detailed advice and directions would be greatly appreciated. On a side not the Haynes manual says the wire from the sensor to the PCM is red/white, mine is green/black. Thanks for any/all help!
Re: 97 Civic DX HB crank no start when warm - Tried everything
I've spent very many hours parts swapping and don't want to have to pay a mechanic.
Maybe paying someone who knows what they are doing would have been cheaper.
The only problem that has caused a CEL is "P0118 Engine Coolant Temperature Sensor 1 Circuit High Voltage" which seems to happen about every 4-6 months and I change it.
Got a scanner that can display a data list?
Thanks for the suggestions. I was a mechanic for many years, didn't have to pay for any parts except the temperature sensor. Sold all my good equipment, only have a basic scanner now....scanner shows no problems...
What did that mean?
What is the coolant temp shown on the datalist during the periods it will not start?
Does that reading remain stable during cranking?
When it won't start, is it missing spark?
Is it missing fuel?
Overfueling?
Have you added fuel (spray carb cleaner) to see if that makes it fire?
Is it missing fuel?
Overfueling?
What did that mean?
Is it missing fuel?
Overfueling?
Is it missing fuel?
Overfueling?
Thanks for the suggestions...
Quote:
This might be a clue.
I'd strongly consider getting hold of a good one somehow.
When problem is present, I'm getting spark to all 4 plugs, proper fuel pressure, no over fueling . Have added injector cleaner to fuel, tried carb cleaner/starter.... Nothing
Compression
Fuel
Spark
In the correct amounts, and at the correct times.
At least one of those isn't right when yours won't run.
I'm gonna wild guess that compression isn't the problem.
Hello,
I was just reading up on this sensor as I pulled the connector, jumped it, thinking it was the thermo fan switch. Car ran like crap (1991 Civic) and produced a code 6. It smelled really rich and after that and when I put it back it was fine. Looks like a sensor that couuuuuuld cause hot start problems..
Here's some testing info if you haven't seen it.
Code 6 - Coolant Temperature Sensor (ECT)
Helps determine the Pulse Width of the injectors at start-up. When this sensor starts acting-up, the engine will get hard to start, on "warm/hot starts". The wax pellet inside the sensor has gotton lazy. Sending bogus signals to the ECU, causing it to flood the engine.
When cold, it should read 2.5-4.5 volts. Also, check the IAT sensor for the same voltage, they should read close to the same. When full warmed should read .5-.6 volts. You can use a resistor with a 330 ohm 1/2 watt spec, or one from Radio Shack part# 271-1113. Start the engine and let it warm up, then kill the engine. Put the resistor in the wire connector on the harness. Start the engine, if problem goes away then replace the sensor. Use this only for temporay testing, it will cause other performance issues. Meaning the ECU will think the engine is always warmed up, when it's not.
This sensor is also known to cause hot and cold starting problems.
Temp F Volts
0 4.70
10 4.50
20 4.29
30 4.10
40 3.86
50 3.61
60 3.35
70 3.08
80 2.81
90 2.50
100 2.26
When the engine is hot, the sensor is telling the ECU that the engine is cold. Flooding occurs, due too a improper injector pulse width. Unplug the sensor if you need to start the car in a hurry. The ECU will throw a code and go into limp mode, however you will be able to drive it.
Temp F Volts
0 4.70
10 4.50
20 4.29
30 4.10
40 3.86
50 3.61
60 3.35
70 3.08
80 2.81
90 2.50
100 2.26
I have a 1997 Civic DX HB, no modifications, completely stock, that will start fine the first time during the day. After I drive it a while and turn it off it will just crank and not start. I have to wait usually about 30-60 min before it starts again. I do not smell gas when it is cranking (I know it only pumps gas for a few seconds). This has been going on for about 3 years and I have not been able to solve it yet. I have went through and tested everything I could find on every Honda forum and have not been able to solve it. Just off the top of my head here are some things I have tried: 7 main relays (new, re soldiered, and junk yard pulls), 3 computers, fuel pump is priming (also tested voltage), replaced fuel filter, correct fuel pressure on valve at filter, tested spark (good), cleaned and sanded all contacts on battery and grounds on car, tested ohms/voltage? at injectors, I have tried/tested all of these things and switched out parts that were possible to switch out while problem was present. Also swapped out 2 fuel pressure regulators (with junk yard pulls), changed internals in dizzy, checked all fuses under dash and in engine. I'm sure I have forgotten a few things but I just wanted to let you know what I have done (as I said as much as I can remember at this time). Car had a major tune up about 2 years ago and only has about 400 miles on it since then. The only problem that has caused a CEL is "P0118 Engine Coolant Temperature Sensor 1 Circuit High Voltage" which seems to happen about every 4-6 months and I change it. Other than that the car runs great! Any suggestions would be appreciated, I've spent very many hours troubleshooting and don't want to have to pay a mechanic. Thanks!
A good scanner that can display live engine operating data in real time is a real asset when it comes to this stuff.
The Engine Coolant Temperature sensor in question has 2 wires:
Red/white and
Green/black
Both lead to the PCM
Red/white is "sensor input" to the PCM
Green/black is "sensor ground" which comes from within the PCM, and several other sensors share the same circuit. IAT and TPS share the same wire, you could jumper to either of those as a test point if you suspect a break somewhere in the harness.
When checking the 2 wires at the sensor, you need to have your voltmeter black lead in the negative port on the tester, and secured to the battery negative terminal. Leave it there.
Use the red lead to check voltages in the connector at the sensor (I like to use a THIN paper clip as the test probe, that way I don't damage the fragile terminals inside the connector.)
Key ON, engine not running: Connector unplugged: One wire should read 0 volts, the other should read 5 volts.
If the sensor is actually connected, the red/white wire should give a voltage reading that would correspond to the temperature-voltage chart....while the green/black should always give a reading of about 0 volts whenever you check it.
Make sense? HTH
Braun
Apr 23, 2015 09:03 PM
