2000 civic starter cranks once
Old Sep 27, 2014
Drich79's Avatar
Drich79 is an unknown quantity at this point
Just started happening, I go to start the car and the starter will only crank one rev. If I hold the key to the start position, it will crank 1 rev every 1 second or so. My car usually starts on the second try. What could this be?
Any help is appreciated!
Old Sep 27, 2014
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Re: 2000 civic starter cranks once
You probably need to check condition of battery and connections. After a good 24+ hour maintenance low amperage charge, with the charge light in the solid green and the battery has set about 24 hours off charge, voltage should be about 12.8 volts.
12.8 = full charged
12.6 = 75%
12.3 = 50%
12.0 =25%
Always check both the terminals at the battery lead and also at the terminal on the wire. That helps to verify connection.
Old Sep 27, 2014
Aftermarket alarm, with a starter cut relay wired in, siren wires have been cut, alarm has been triggered?
Do you hear relays clicking in the dash at one second intervals?
Otherwise, I'd be checking starter circuits...Test light? Voltmeter? Wire diagrams?
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
