Heater stopped working!!! 99 Civic Si
Old Dec 31, 2013
Rsolis94's Avatar
Rsolis94 is an unknown quantity at this point
I was using my heater earlier in the morning and it was working fine. As the day progressed it got hotter so I turned off the heater. Later at night when it got cold again I turned on the heater but it never got hot. Also when i change the direction of the air it stays pointing towards me. I try to change it to the feet or the defroster but it still blows threw the front. Help please!!!
Old Dec 31, 2013
Re: Heater stopped working!!! 99 Civic Si
What DOES work in the heater/AC system?
Does the water valve open and close when you switch between hot and cold?
I'll guess:
Sounds like the control panel isn't controlling the mode actuator and the temp (air mix) actuator, but will it still control the fan? Recirculate? Pushbuttons?
Check fuses 47 (engine compartment fusebox) and 17 in the dash fusebox.
There's a self diagnosis check for the air mix motor in the service manual.
There's troubleshooting info in the manual.
Almost all troubleshooting is going to be observation (what does or doesn't work) and electrical checks (why doesn't it work) with a wiring diagram or trouble tree and a voltmeter.
Or find an identical car and swap the HVAC control panel and see what happens.
HTH
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
Richkid23
Apr 19, 2015 12:53 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
