2000 honda civic se O2 sensor
Hello, earlier today I had the check engine light come on so I used the code reader and the code came up P0135 which from what I've read is the upstream o2 sensor malfunction. So I went and took off my sensor and brought it to autozone but I met two problems when I got there, you can't search under civic se and they didn't have a sensor that matched mine.
Whenever I look online there isn't a search option for the se either so I'm not really sure which sensor I should buy, does anyone have any suggestions?
Re: 2000 honda civic se O2 sensor
http://www.hondaautomotiveparts.com/
Use the option where you enter your VIN instead of selecting your car.
O2 sensors are listed under 'exhaust manifold' and/or 'exhaust pipe', depending on the version of the car.
Find the correct part number, and order it.
OR
Pull out your old sensor, it SHOULD be either NTK or DENSO. Replace with the same brand.
Installing any other brand is just asking for trouble.
Find the correct factory part number and cross reference with the DENSO or NTK websites and catalogs, whichever brand yours is.
OR
JetsterDajet
52
May 8, 2016 12:11 AM
jdh022764
18
Nov 3, 2015 06:44 AM
pfwel1977
Sep 10, 2015 02:16 PM
dantheman42
Sep 4, 2015 01:10 PM
