99 civic sputtering
Old Nov 4, 2013
cannibal_carnie's Avatar
cannibal_carnie is an unknown quantity at this point
99 civic sputtering
I just picked up a 99 civic with a d16z6 swap. Mods on engine are new distributor new plugs new wires has a complete Turbo setup done poorly though install wise looks like crap but seems to be building boost fine. My issue is that car has a slight miss at idle but when you they to rev the engine the throttle has a delay and when it does start to rev it makes the engine sputter badly until the rooms are above 3000 then the throttle response is fine in that rpm range but any lower and it putters again. This issue makes it nearly impossible to take off from a stop. I checked the timing and it is spot on. I have no cell either. Only thing I can see is the tps sensor is broken where the plug is. Can this be my issue or is it something worse. Thanks for any help
Old Nov 4, 2013
Re: 99 civic sputtering
Sorry for typos auto correct on a junk phone. Meant to say engine sputters with throttle at any rpms below 3000 rpm
Old Nov 4, 2013
Also I have no cel
Old Nov 4, 2013
Fliptard's Avatar
Fliptard will become famous soon enoughFliptard will become famous soon enough
I would get a new TPS and adjust it Per Honda spec and go from there.
Was this car actually tuned by a tuner and dyno?
Old Nov 4, 2013
I'd say no it wasn't tuned just a back yard mechanic job
Old Nov 5, 2013
Fliptard's Avatar
I would look into Hondata and a chipped P28 and get it tuned. That way it'll be running like it's suppose to and won't cause you more money down the road.
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
