2000 Honda Civic Dx Break Light problems
Old Sep 22, 2013
DonavanJ's Avatar
DonavanJ is an unknown quantity at this point
Exclamation 2000 Honda Civic Dx Break Light problems
Well, to start off, as the title says, i have a 2000 Honda Civic Dx Coupe. Ive recently had issues with the breaklights not wanting to come on. Ive changed the break switch, all the bulbs in the back, and i have checked the fuses. I saw in a previous thread that if the light in the back window was not working then it had to do with either wiring, or there being something wrong with a ground. I need help with figuring this out. Thanks!
Old Sep 23, 2013
CraigW's Avatar
Re: 2000 Honda Civic Dx Break Light problems
Do you own a multimeter, or 12 volt test light ??
When the problem is occurring test at both sides of the brake switch is where I would start.
1 side should have constant 12 volts, and other side 12 volts when pedal is pressed.
jessicakaybby
Apr 20, 2015 12:11 PM
ashleymmackey
Apr 18, 2015 09:48 PM
dooner24
Apr 14, 2015 07:51 PM
liljoe
Nov 4, 2001 01:27 PM
