1998 civic cx compression test
Old Sep 2, 2013
cgarza1's Avatar
cgarza1 is an unknown quantity at this point
Hey everyone,
Let me first say this is my first honda. I paid 1300 for my little Hondo Civic with160,000. miles. the Problem I'm having is number one cylinder isn't working. I did a compression test on cylinder 1 and was getting 30. The other three I was getting 140 to 150. I did put oil and in cylinder 1 with no change at 30. Is this a common problem with these cars? What should I look for next?
Old Sep 3, 2013
Fliptard's Avatar
Fliptard will become famous soon enoughFliptard will become famous soon enough
Re: 1998 civic cx compression test
Leak down test will tell you I it's rings, headgasket or valve issue
Old Sep 3, 2013
I'd probably say to first pull the valve cover and check valve adjustment. Tight valves can cause low compression.
Tight valves also burn if ignored too long.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
BREADFAN
Apr 15, 2015 08:58 AM
Hrddrvs
Apr 11, 2015 11:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
CapYoda
Nov 11, 2001 05:17 PM
