96 civic ex overheating like crazy!!!!
Old Aug 23, 2013
96 Honda civic's Avatar
96 Honda civic is an unknown quantity at this point
Hi everyone, well my 96 civic is overheating and I don't know what to do! I have fix the water pump, time belt, and even install a new radiator becux the old one pop. My car is still overheating. My car is blowing white smoke from what my friend says and the engine ol is like chocolate looking. What should I do?? How can I fix it? And also will a head gasket repair it?
How can I fix this??? I would appreciate the advises!
Old Aug 23, 2013
Poopies's Avatar
Super Moderator
Re: 96 civic ex overheating like crazy!!!!
A way to diagnose your head gasket is to check the coolant level. If you've been filling it up pretty often then that is a good indicator. Is your ECU throwing any codes?
Old Aug 24, 2013
localkineguy's Avatar
localkineguy is an unknown quantity at this point
look for oil in your coolant. You might want to drain your coolant and then refill. if you have recently replaced your radiator, then the coolant flush is not necessary.. Just look for oil in your coolant
Old Aug 26, 2013
Fliptard's Avatar
Fliptard will become famous soon enoughFliptard will become famous soon enough
also, open your radiator cap and let the engine run, but watch the temp gauge, as the car warms up, the coolant in the radiator will start bubbling if the head gasket is bad. It may still be bad and not bubble a lot because is not leaking bad.
That's one way to check for a bad headgasket. You can also do a leakdown test.
Old Sep 15, 2013
Brettbokern's Avatar
Brettbokern is an unknown quantity at this point
I am having the same problem. I have replaced the water pump, radiator, radiator cap, set the timing, and still over heating. I'm out of ideas as to what to do. Did you figure out what was wrong.
Old Sep 15, 2013
youmadeyou's Avatar
youmadeyou is an unknown quantity at this point
I'm Opinion , Sounds like you have a Cracked or Warped head ... I would replace or Have your head checked and or Reservist ... All things you said in your comment points to this ... hope this helps . Sorry about your luck.
Old Sep 16, 2013
Fliptard's Avatar
also, make sure your PCV valve is not clogged, if it's not working correctly, it can make the car smoke like crazy and loss of power
Xuhme
21
Aug 7, 2023 03:40 PM
usajags84
15
Aug 19, 2015 03:12 AM
jessicakaybby
Apr 20, 2015 12:11 PM
deus-ex
Apr 13, 2015 12:29 PM
colombianDXcivic
Nov 8, 2001 05:26 PM
