5 speed 97 Honda Civic Cruise Control problem
Old Jul 31, 2013
dietztho000's Avatar
dietztho000 is an unknown quantity at this point
Just purchased the car a few weeks ago to go from home to school.
Cruise doesnt work.
Did some searching.
I hit the main switch, the light turns green.
Get to desired speed and then press the SET button.
The Cruise Control light on the dash cluster lights up green for a second and then turns off.
I got it to work once but now all my trys are effort less.
Looked at the brake switch, the button is down when the brake is not set, then the button pops out when the brake is pushed.
Checked the lower switch on the clutch and the same as the brake switch.
SO it seems those are correct, I believe.
Looked at the vacuum lines, and they seem good.
My horn is on its way out (doesnt sounds loud, dieing) but not completely died.
SO I dont think its the clock spring.
Also checked the fuse in the inside compartment and it was good.
Any other suggestions?
Old Jul 31, 2013
Re: 5 speed 97 Honda Civic Cruise Control problem
Try holding your left foot under the pedals, and lift up while engaging the cruise. If it works like that but quits when you let go of the pedals, then it's a pedal switch.
Revisit the pedal switches, look for a missing rubber pad where the plunger(s) makes contact with the pedal(s).
If no joy, then get a wiring diagram. Test each switch, use a voltmeter this time. I can do all my initial electrical tests from the control unit connector. If nothing there, then I'd use the wiring diagrams to test the rest of the system....but it sounds like a flaky pedal switch.
Old Jul 31, 2013
Thank you for the reply!
I've tried those methods too on both the clutch and brake with no luck.
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
