96 honda civic problem!! Help!!
Old Jul 29, 2013
KrisHino77's Avatar
KrisHino77 is an unknown quantity at this point
So a couple of weeks ago I installed the drivers side power door on my hatch and it worked well I installed the power wires into the fuse box... A couple of days ago I installed the passenger side power door. When I finished I tested it from the passenger side and it seemed to be working then I tested it from the drivers side and the passenger window went up and down. So then I switched the window lock from on to off and the doors stopped working. I tried to turn the car on and it wouldn't start not even a click or a sound just won't start.
I checked the starter but the starter is fine. I checked the clutch safety switch and that wasn't it I pulled the fuse box and checked for burn marks but nothing. Then I tested the box for power with a tester and it gets power the headlights work the radio works signal lights work the only thing is my doors and the car won't start.
Please help!!! If you need more info please ask thank you!!
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
