AC Draining Inside Car!
Old Jul 4, 2013
fjd_98's Avatar
fjd_98 is an unknown quantity at this point
Passenger side floor is filling up with water when air conditioner runs. What do I do?
Old Jul 4, 2013
CraigW's Avatar
Re: AC Draining Inside Car!
Sounds like your drain tube is plugged in some way.
Not sure of the best way to clear. Maybe ezone will chime in.
It is near the firewall area underneath, a black tube hanging down.
Old Jul 4, 2013
Drain hose/tube either clogged or disconnected. I have no idea what your car has without looking. Stick your head under the dash and take a look while it's dripping. If the drain tube is clogged, remove it from the bottom of the evap case and either poke it out or use an air gun to blow through it... If the clog is inside the plastic housing, that's a lot more work... I used to see them when people kicked the hose loose from the bottom of the evaporator case. Simply reinstall, maybe wrap a hose clamp around it.
Old Jul 5, 2013
CraigW's Avatar
So the evap drain and the top of the drain hose is easy to access in the footwell area ??
Old Jul 5, 2013
I have no idea. Some are, some aren't. I can't see the car, I don't know what car OP has, and there aren't any here on the premises handy to look at.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
roverben
Jan 21, 2019 05:16 PM
tylerginevan
Apr 27, 2015 12:29 PM
cperez53
Apr 16, 2015 09:31 PM
BREADFAN
Apr 15, 2015 08:58 AM
