'98 Civic Engine Swap
Old Jun 17, 2013
sportsfantic35's Avatar
sportsfantic35 is an unknown quantity at this point
I own a '98 Honda Civic and I was wondering is you are able to put a manual engine with an automatic transmisson
Old Jun 20, 2013
Levi likes si's Avatar
Levi likes si is an unknown quantity at this point
Re: '98 Civic Engine Swap
Yes you can. I am in the middle of swapping a auto engine to a manual tranny all you have to is remove the auto flywheel and bolt the manual flywheel and clutch assembly to the crank shaft, you can't use the same bolts from the auto Flywheel as they are to short. Hope this helped
Old Jun 20, 2013
In your case the opposite of what I said earlier
Old Jun 20, 2013
To help illustrate you point, and since I just so happen to have one of each laying around, here's a side by side comparison of a bolt that attaches an automatic flex plate (right) vs a bolt that attaches a manual flywheel (left).
Edit: stupid.. Upside down... iPhone.. Pic...
I just so happen to be swapping out the bottom end of my engine that's mated with a manual transmission with one that was previously attached to an auto transmission
Edit 2: also, from a 2002 Ex. Same concept though. I mean, they use the same clutch, even.. Lol
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
beneditti
Jan 15, 2016 12:31 PM
usajags84
May 10, 2015 08:11 AM
BREADFAN
Apr 15, 2015 08:58 AM
shawe90
Apr 14, 2015 07:10 PM
