98 civic dx clicking sound behind glove box
Old Mar 24, 2013
CAM I AM's Avatar
CAM I AM is an unknown quantity at this point
my 98 civic dx has a clicking sound behind the glove box and will not start i took out the main relay where the sound was coming from and replaced it with a new one and i am getting the same sound out of this one and the car still want start please someone help me figure this out this is my work car and i have to get it running again so i can give my wife her car back
Old Mar 25, 2013
marshallinux's Avatar
marshallinux is an unknown quantity at this point
Re: 98 civic dx clicking sound behind glove box
simple things first, have you checked the battery connections?
Old Mar 25, 2013
CAM I AM's Avatar
Yes i have that was the first thing i did car has a brand new battery and a strong connection volt meter was registering 13
Old Mar 27, 2013
have you done tests like these also?
http://www.agcoauto.com/content/news/p2_articleid/253
Old Mar 27, 2013
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Are you sure the sound is from the glove box and not under the hood? what is the car doing when you turn the key? Do you have spark, does it try to start? Need more info...
The Main Relay will click three times during the starting process. When problems arise, one of those clicks (usually the third) is missing, making those clicks a handy diagnostics tool. If you consistently hear/feel all three clicks, the Relay is fine. DO NOT REPLACE IT.
  • Turn ignition to ON (but not to START): Click 1
  • Check Engine light goes off: Click 2
  • You now turn the key to START: Click 3
Waaay up under the dash on the driver's side, up behind the dash in a diabolically difficult place to get at lurks a critical device known as a PGM-FI Main Relay, or EFI Main Relay. Honda usually places the Main Relay very close to the ignition switch, for obvious reasons, and they all look the same (albeit with slightly different colors and part numbers), so these photos should help you locate yours.
The photo sequence below shows the PGM-FI Main Relay location for the '90-'93 Integra, one of the easier vehicles to deal with for this item. Many other Hondas very frustratingly have their Main Relay in basically the same location, but above the hood latch, which seems innocuous enough, but creates huge headaches (see more photos below).
In all cases, you need to remove a large piece of plastic trim called the Knee Bolster. This trim covers all the wiring and structural members that festoon the area immediately under the steering column.
1) View of under-dash of '90-'93 Integra. The knee bolster is the filler panel under the steering wheel. The coin box is in it.
2) Pop coin box loose on one side with a screwdriver to push the pin out of its recess. Careful not to mark up the dash or break something. It doesn't take much effort to release the pin.
3) Remove remaining screws and pull rearwards to carefully pop tabs loose on top. Knee bolster is now free.
4) It's under there! It's always close to the ignition switch.
5) There are two relays in this particular location. It's the larger one behind the small one.
6) Another view. Camera was held near floor and pointed upwards.
Two quite awful locations chosen by Honda
'88-'91 Civic/CRX.
THIS is the "diabolically difficult place" the text above refers to.
Here, you are the center console (you always wanted to be one, didn't you?), and are looking towards the left (driver's) side of the car.
In this car, you have a choice:
1) You can pop the guts out of the casing (see below), leaving the casing in place, or
2) You can remove it by undoing the fixing bolt (see below).
Neither method is fun, and either will take you about a half-hour of fiddling back-and-forth.
'92-'03 Civic/CRX.
It's a bit better than the '88-'91 Civic, but not as good as the '90-'93 Integra. Yours may be here if it's not in the Integra's location. The knee bolster has been removed here as well.
Notice this particular Relay housing is grey instead of black, and the bracket is pointing upwards.
In these two pictures, you'll notice the plastic trim that's in front of the bolt that holds the Main Relay on. It's this trim that makes the Relay so hard to get off the car, since it prevents the application of a socket to the Relay's bolt.
It appears to me that you could easily unbolt this Relay by heating up a very small wrench with a torch, and bending it right behind the head..
Tips for the '88-'91 Civic:
Removing guts from the casing
If you are unable to remove or flex the trim in order to get at the bolt, you can simply remove the guts of the Relay from its casing. Get a very small flat-blade screwdriver, and pull the locking lugs outward (the lugs are on the short sides of the Relay).
Start with one side. Push the screwdriver gently between the Relay housing and its bottom plate, and pry outwards until that side releases. Tilt the bottom plate on an angle to keep the lock from re-engaging, then do the other side. After the guts have been removed, you may unplug the electrical connector.
This approach may be more trouble than it's worth though, so you might just want to try unbolting it anyway. Read on...
Unbolting the entire Main Relay
In this pic, you're lying down on the floor of your car, looking skyward. The mounting bolt is directly vertical above the outboard edge of the hood release in the pic. The Relay's mount bracket points downwards, so the bolt is lower than the Relay.
From jim beam:
"It's
one of those guys you unscrew half a flat at a time, then flip the wrench over - you know the type? it helps to get the hood release out of the way too. Then the next most fun thing is unplugging the wiring. It's held by cable tie to the body, about 1" from the plug, so you have no room to maneuver. But there's room to pop the mounting for that tie-mount with a screwdriver or pair of needle-nosed pliers. Once the Relay's free to move, then puzzling it out is merely an exercise in patience. Even if you know where the wretched thing is & what you're doing, it's still a half-hour job!!!"
What the Main Relay looks like up close:
Some of the casings seem to be grey and some black. Sometimes the bracket points up and sometimes down. Incidentally, the bracket can be easily pushed off and remounted the other way if you need to do that.
This particular one is out of a Honda CRX but I don't know of any Hondas that don't use one of these things. Inside its casing there are actually two relays mounted to a printed circuit board. Here's a picture of the beast with its cover removed.
Since relay coils are relatively heavy, and the relay assembly is bolted solidly to the car, vibration sometimes causes hairline cracks to form in the solder joints on that printed circuit board. This can cause intermittent failures, which are especially likely to happen when the car has been parked in the sun on hot days.
When you turn the engine over, there is enough pressure in the main fuel rail to supply the injectors, so the engine starts, the ECU re-applies the ground to the second relay and the fuel pump runs continuously from then on. So if your car won't start, listen for that fuel pump! If it doesn't run for two seconds each time the key is turned from the off to the run position, you're not going anywhere, and it's probably a sulking main relay that's the cause.
Another common problem also caused by the main relay is that the car starts fine, but stalls as soon as you release the key. In this situation, it may take many attempts at starting before the car will continue to run with the key released. Posts complaining of this seem to peak during warm-weather months.
How does the Main Relay work? Click here. (Has pictures too!)
How to fix? Well you can just replace the damn thing, or pay a mechanic to do it. Or if you know how to pilot a soldering iron, you can touch up those soldered connections on the printed circuit board. It's not hard to get the cover off, it's just held on by plastic tabs at the edges. The main difficulty is just getting at the thing. For fault finding instructions here's a good site
And here's a site with more info on fixing it.
Another possible cause of the same symptoms can be lurking further up the same chain of interconnections. The ground that the ECU supplies to the second relay isn't anywhere near the ECU. It is in fact way up front on the engine! There are several wires originating from the ECU that are grounded on the engine block (probably so there won't be problems with bad engine to bodywork ground straps). On the CRX these wires are attached near the thermostat housing. Other models may differ. If the connection of these wires to ground is loose or corroded, you can get symptoms similar to a bad main relay.
Old Mar 27, 2013
CAM I AM's Avatar
yes the sound is coming from behind the glove box i have taken the glove box out so i could get to the relay. when i turn the ignition on the relay continuously clicks when i try to start the car it does nothing motor does not even try to turn over... i just did the test on the relay its self that was recommended to me im getting power to the relay but nothing further than that no power to the ecu side of relay fuel pump or ignition so im now 90% sure it is my relay from doing the test that ya'll have recommended to me thank you guys so much for the help and if this new relay does not work i hope ya'll will continue to give me good feedback and suggestions once again thank you so much for the help
Old Mar 28, 2013
Gunner's Avatar
Be sure to let us know how it goes
Old Mar 29, 2013
CAM I AM's Avatar
Ok guys here i am again at a loss i went and got the new main relay and installed it (plugged it in) and my car still will not start I'm still getting the same sounds from the new relay as the old one it is a constant noise i tried to upload an audio clip of the sound and then a video of it as well but would not let me post kept telling me invalid file. the reason for the video clip is cause when the ignition is turned on and noise is coming from the relay my speedometer begins to jump around. i can email the video clip and audio file to whom ever so you can here and see what happens when the key is turned on. please just message me with the email address you would like me to send the clips to if you think you can help. Thank you great people for all the help so far and I'm sure with more help from this forum i will have my honda up and running again before long.
Old Apr 2, 2013
CAM I AM's Avatar
Well after days of testing wires and tracing them down I have found the problem it was in my ignition switch one of my wires had shorted out causing my main relay not function properly after replacing the ignition switch the car runs just fine now. Now that my problems are fixed I can get back to my modification that I have been working on thanks to all your help with my problems with my civic it was a great help
Old Apr 8, 2013
Gunner's Avatar
Glad to see you got it fixed. well done.
roverben
Jan 21, 2019 05:16 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
EXWisdom
Nov 5, 2001 10:24 PM
