d16y7 oil pan stuck
Old Jan 10, 2013
logK89J29's Avatar
logK89J29
logK89J29 is an unknown quantity at this point
d16y7 oil pan stuck
hi so i'm trying to change my oil pan on my d16y7 automatic it's a 1998 civic dx and the oil pan seems really stuck..here is a recap of what i did just so you know where i'm coming from.
i removed the down pipe on the exhaust to better gain access to the oil pan bolts.
i removed the engine stiffener (the bracket between the engine and trans) to gain access to the oil pan bolts
and i also removed the torque converter cover just to get it out of the way.
I removed all the nuts and bolts on the oil pan (10 nuts and 8 bolts is that correct?) and whacked it with a mallet yet it still won't come off. i guess i was holding back a little for fear of damaging the oil pan. should i just go to town on it?
any tips?
EDIT: also does anyone know the torque specs for the torque converter cover
Old Jan 11, 2013
swagger9000's Avatar
swagger9000 is an unknown quantity at this point
Re: d16y7 oil pan stuck
After you remove that bracket, the service manual says just remove the bolts and nuts and it will come off. The torque when re tightening them down is 8.7 lb*ft or 12N*m
Old Jan 11, 2013
logK89J29's Avatar
logK89J29
haha, i got it guys
just a few GOOD solid whacks with my trusty rubber hammer and it came right off.
wish i'd drained the oil before tho ;-)
and btw it is 18 nuts and bolts total for the d16y7 oil pan fiy
brags
46
Jan 7, 2016 09:39 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
ballmich
Jul 9, 2015 11:59 AM
