just cranks
Old Nov 9, 2012
bobbytee98's Avatar
bobbytee98 is an unknown quantity at this point
Unhappy just cranks
have a 97 honda d16y8 that just cranks
replaced ignitor,coil,crank sensor,main relay ,tried a good pcm,
changed spark plugs,checked the fuel pressure was up to spec
have good compression.
checked all ground connections.oh yes checked my timing its right on.
checked after market alarm wires and relay all looked good.
all fuses checked out ok.should i just yank out the alarm system
don't know what else to do.
car was running great,went to store tried starting and it never did.
any ideas?
Old Nov 10, 2012
azkicker0027's Avatar
azkicker0027 is an unknown quantity at this point
Re: just cranks
just a thought, spray some carb cleaner past the throttle body via a vacuum line/hose and then start it up. maybe the injectors are not pulsing. just a thought.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
68camerors
Sep 24, 2015 06:18 PM
Skunkone
Sep 24, 2015 04:38 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
