Needing parts
Old Oct 6, 2012
arizaga8799's Avatar
arizaga8799 will become famous soon enough
Needing parts
i started over heating again after changing the ect sensor on my way to Yorba Linda on the 40 and came across my fan not kicking on but it's a Saturday and everywhere around this area has to order the fan assembly. is just replacing the motor a better option than order the whole assembly? also what's a good brand for the fan sensor? I'm Gunna replace that also can't have no problems going up cahone!
Old Oct 6, 2012
Re: Needing parts
If the fan blade isn't melted, damaged, or broken....see if it will come off the motor without damage. If it will, then reuse it (with an OEM motor). This means taking it all apart before ordering anything.
Aftermarket can be a crapshoot, you never know if it will be exactly the same as original. Blade may or may not fit.
Fans and motors are not identical-- right/left sides. Be sure of which you are getting. And be sure of what someone else is ordering.
Also, the little bitty screws that hold the motor to the fan shroud are usually corroded and stuck here. Heat will get them out but can melt the plastic shroud, and cutting them off can melt it too.. I always order new screws with a motor.
OEM parts all the way for me.
I'd be diagnosing it FIRST to be sure of what the problem really is.
Old Oct 6, 2012
Re: Needing parts
I bought the fan switch and motor and the fan switch turned out to be the problem so no need to replace the motor so I returned it!
mattdoc
Mar 14, 2017 12:10 PM
usajags84
15
Aug 19, 2015 03:12 AM
bsmiley
Apr 27, 2015 01:27 PM
Myredjonda
Apr 14, 2015 07:00 PM
2k1Vtecivic
Nov 3, 2001 10:37 AM
