sputtering question
Old Oct 2, 2012
catfish22's Avatar
catfish22 is an unknown quantity at this point
sputtering question
I have a 2000 Honda Civic VP with 187,000 miles. I just changed the upstream oxygen sensor about a year ago and it was running smootly until yesterday when it started sputtering badly and the check engine light came on.
I brought it to AutoZone for a code check and one of the codes was PO135, which I think is one of the oxygen sensors. How do I know which one it is (upstream or downstream). Since I changed the upstream sensor less than a year ago, I think it could be the other one.
Any help would be appreciated.
Old Oct 2, 2012
Re: sputtering question
P0135 is for the heater circuit of the front O2 sensor.
That's the upstream one.
Old Oct 2, 2012
catfish22's Avatar
Thanks.
Old Oct 2, 2012
judas009's Avatar
judas009 is an unknown quantity at this point
check your exhaust manifold for cracks. mine was doing that and threw that code and low and behold i had a cracked exhaust manifold.
Old Oct 11, 2012
arizaga8799's Avatar
arizaga8799 will become famous soon enough
you could also gave a bad connection between the sensor and the harness I has a loose wire and I stuck it back in and it stopped all sputtering.
tuvok
Sep 25, 2015 03:13 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
cgavin1
Jul 7, 2015 07:10 AM
