Engine Type
Old Aug 20, 2012
roverben's Avatar
roverben is an unknown quantity at this point
Engine Type
Sorry if i'm posting in the wrong forum, but i have a 1999 civic si (vtec) and i would like to if it's a B16A2 motor. Thanks.
Old Aug 20, 2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
Re: Engine Type
It should be if it's an Si...if it's an EX, it would be a d16y8.
You can check by looking on the engine block right next to where it bolts to the transmission...theres a little flat spot that has the engine code stamped into it.
Also, the B16 has two cams, where as the d16 has one.
Old Aug 21, 2012
roverben's Avatar
Re: Engine Type
Thanks.
Old Aug 22, 2012
roverben's Avatar
Re: Engine Type
I checked on the engine block and found D16Y8. Is it possible to have this in my SI coupe or do you think this motor was changed, because i only bought this car about 5 years ago. Now whenever i buy parts i have to ask for parts for a 1999 EX.
Old Aug 22, 2012
Aetoc's Avatar
Re: Engine Type
It's highly unlikely that the car was manufactured that way...although if you check the vin # you can tell for sure...if its an EM1, then it's an Si and should have the B16, if it's anything else, then its a D16, unless it's JDM (eg, the EK4)
Old Aug 22, 2012
Re: Engine Type
Wait, quick question.. You located in Canada or the US?
Old Aug 22, 2012
Aetoc's Avatar
Re: Engine Type
That's why I meantioned chassis codes, the EM1 is the same in the US and Canada, the Si is not...in Canada, the Si is the same as the US's EX, where as the Canadian equivilent to the US Si is the SiR
Old Aug 22, 2012
roverben's Avatar
Re: Engine Type
I'm located in Canada and this car was manufactured in the US.
Old Aug 22, 2012
Re: Engine Type
Nevertheless, the USDM ex is marketed in Canada as the Si model. If you had an SiR, your car would have a B16
Old Aug 23, 2012
roverben's Avatar
Re: Engine Type
Thanks for all the info. Much appreciated.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
One_PeeJay
May 17, 2015 05:31 PM
TaiChi
Dec 17, 2001 09:09 PM
supercivic01
South
Nov 30, 2001 11:27 AM
