98 civic ex not firing
Old Jul 14, 2012
COSMOE CRAMER's Avatar
COSMOE CRAMER is an unknown quantity at this point
Exclamation 98 civic ex not firing
i have a 98 EX, and i was on my way to drop my kids off at the babysitters house. it started up fine and when i got to the first light i stopped, and when it turned green it died. the car is getting fuel to the engine, but there is no fire. i have changed the cap and rotor, and tested the coil pack it is fine, and we have changed the ICM. Still no fre. Help this is our only car and i need to get it fixed ASAP.
Old Jul 15, 2012
Re: 98 civic ex not firing
What method did you use to check this?
Old Jul 15, 2012
We used an ohm meter to check the coil pack, and we used a test light. the primary and secondary are within specs. just no fire out of the secondary. i am thinking it my be my neutral safety switch as the car died when i was letting my clutch out. any sugestions?
Old Jul 15, 2012
A) An ohm meter won't figure this out.
B) What did you test with the test light?
C) Do you have a dwell meter?
Nope.
any sugestions?
Learn what the neutral safety switch is for, and you should then understand why this cannot be the cause of your problem.
Old Jul 15, 2012
we tested the positive and negative terminals. the light stayed on constantly and did not flicker on either of the terminals.
Old Jul 15, 2012
Got any codes?
Depending on the light characteristics and due to the dwelltime involved, an incandescent lamp MIGHT NOT flicker. An LED test light MIGHT have been better to use.
Use a dwellmeter to test.
Do you know how to use one?
(We used to use them all the time back in the good ol' days of points and carbs.)
Set to 4 cylinder scale.
Connect it to the neg. side of the coil and to battery ground.
Crank the engine.
If there is ANY reading at all (even only 2 degrees), the ICM is trying to fire the coil, and the coil is bad.
If the dwell reading is 0 or 90, the problem is elsewhere. Something isn't even trying to fire the coil.
See, most of the time I see these with a hole burned through the side of the coil. It may still make a tiny spark out of the tower, but the spark will seek the closest ground when stressed, and that is the metal shield around the coil. The coil would pass all tests except for the actual sparks output.
I bet the coil is bad, no matter what your ohmmeter said.
HTH
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
Blaster30
Apr 22, 2015 12:21 PM
AlexLx
Nov 7, 2001 10:09 PM
silvervtec01
Nov 4, 2001 06:56 PM
