o2 sensor inside catlytic converter
Old May 21, 2012
Tnyce's Avatar
Tnyce is an unknown quantity at this point
Hi,
I am the original owner of a 1999 Civic SI with 187k. The check engine came on recently, and I was told it was for an oxygen sensor. I took it to the shop and they said it was inside the catalytic converter, and that I needed to replace the entire catalytic converter which could cost $700 dollars if it is the rear or $900 if it is the front. I could have mixed those two figures up. Does anyone know if this is correct? Do I really need to replace the whole catalytic converter? If so, is there a good place to get a salvage or less expensive one?
Old May 21, 2012
Re: o2 sensor inside catlytic converter
Let's start with solid data.
Post the code number.
Go to AutoZone and get the code read if you have to.
Don't post the parts list they want to sell you.
Just the Pxxxx code number.
Old May 22, 2012
Tnyce's Avatar
The code is PO420
Old May 22, 2012
It needs the cat, not the Oxygen sensor. 99% sure.......
But exhaust leaks can cause a false cat code.
If there are no leaks between the engine and to a couple feet past the cat, and the computer has good control of the fuel delivery, then it most likely needs a cat.
Heck, at that mileage it probably needs a cat no matter what.
Cat is item #4 here, if I got the car correct:
http://www.hondaautomotiveparts.com/...5=EXHAUST+PIPE
Gaskets and hardware are extra, to do the job right.
I'm sure you can find cheaper parts, but as always, you get what you pay for.
The sensor can be reused IF it comes out of the cat without damaging the threads. I'd make sure it will unscrew before I make the estimate for the cat job, so I can include it if necessary so there are no surprises during the job.
Many people will tell you to replace the O2 sensor(s), but it is the cat that is bad, not the sensors. (99% sure, 1% unsure. There are many other codes that address the O2 sensors themselves.)
You will spend $100-$600 on sensors, only to find out the cheapos don't work right, they can't be returned, and it STILL needs a cat.......and now you don't have any loot left.
HTH
Old May 22, 2012
Tnyce's Avatar
Thanks. very helpful information. It looks like I will be shelling out a good chunk of change.
Old May 22, 2012
Make sure all of the ignition stuff is in good shape too.
Misfires can kill a cat in a hurry, no matter how new it is.
ezone
24
Oct 30, 2017 11:27 AM
docmartin14
Jul 30, 2015 11:26 AM
Fastfebur
Apr 26, 2015 11:57 PM
kevin99ek
Apr 23, 2015 09:32 PM
jessicakaybby
Apr 20, 2015 12:11 PM
