2000 civic rear oxygen sensor installation
Old May 8, 2012
nickrolando's Avatar
nickrolando is an unknown quantity at this point
http://www.ebay.com/itm/NEW-DENSO-OE...item5891150bc9
I replaced my catalytic converter last night. Car is running great now. I do need a new o2 sensor though. I looked online last night looking for the best price as right now I am on a budget. I found the above on ebay.
Will this be a direct fit for my 2000 civic ex d16y8 motor 5speed MT?
Also once I removed the old o2 sensor out of the top of the catalytic converter, can someone tell me how to unplug and plug in the new one?
Thanks so much in advance, you are all so helpful
Old May 8, 2012
CO671's Avatar
CO671 is an unknown quantity at this point
Re: 2000 civic rear oxygen sensor installation
Well if anything; here's a selection. I'm aware you mentioned you're using a y8 and the Ebay listing was of a different product code from that found in this list:
http://www.rockauto.com/catalog/x,ca...,parttype,5132
Old May 8, 2012
I cant afford the rockauto ones. I'm on a budget. Rock auto has the Standard SG614 and the ebay auction i left the link to states these are the part #'s for it:
DENSO # 234-4098, 2344098
HONDA # 35532P2PA01, 36532P2PA01
STANDARD (SMP) # SG614
Where did you see a different product code? I enter my car details and it says it fits and the stock interchange # it states is "35532P2PA01" which is the part # i got off Majestic Honda Parts?
Old May 8, 2012
WalkerTech's Avatar
WalkerTech is an unknown quantity at this point
Nick, I am a product specialist with Walker Products, a manufacturer and worldwide distributor of oxygen sensors. The Ebay part is the correct, direct fit part for your downstream O2. All you should have to do is unplug the old one and plug in the new, very simple.
Old May 9, 2012
Thank you!
Old May 21, 2012
Tnyce's Avatar
Tnyce is an unknown quantity at this point
I don't have an answer for you, but I have a similar issue with my 1999 Si 187k. I was wondering where you got your cat from and how much it cost? Is it necessary to replace the cat if the o2 sensor inside is bad?
rcolosi
Apr 29, 2015 07:48 PM
bsmiley
Apr 27, 2015 01:27 PM
shawe90
Apr 14, 2015 07:10 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
