ignition coil wires
ignition coil wires
can anyone help me find the wires that go to the ignition coil from inside the dizzy? when my coil went out i bought a new one but the screws holding the terminals on the coil were stripped to hell and back. so for a temp fix i cut the wires and soldered about an inch of wire onto the end so it could reach the coil. now i have a misfire above 4500 rpm.
ive tried looking on majestic and the image shows the wires but no part number.
does resistance matter on these wires? or can i just use some speaker wire or something?
Re: ignition coil wires
You probably still have a loose connection: Maybe one of the terminals at the igniter missed the blade sticking out, or one of the female terminals is sprung and fits loose, or your wire splices aren't making good contact.
Long ago, Honda sent us a set of crimpers for tightening the female spade connectors that attach to the igniter because they tend to loosen up over time and miles, causing misfires-- usually at high RPM when the buzzing vibrations have the most effect.
I have even seen a tach rise far beyond actual RPM because of loose terminals.
You can make your own wiring if need be, but it needs to be heat resistant, tight, well made, well insulated, and reliable.
Try to use the same wire gauge as was in there originally.
All wiring and connections should have 0 ohms of resistance.
You might be better off finding a used distributor to steal the wiring out of. I'd probably still pinch the sides of the female spade terminals so they grip tight upon installation.
HTH
HTH
HTH
HTH
if all else fails i will probably find a dizzy at a yard or something and grab the wiring like u said.
mrohitredd
May 28, 2015 10:03 AM
deus-ex
Apr 13, 2015 12:29 PM
