Alright I need help
Old Mar 28, 2012
KenL's Avatar
KenL is an unknown quantity at this point
Alright I need help
Hey guys, I am having a problem and just can't seem to figure it out. I was driving today and all of a sudden I heard a clank sound and the engine went from its normal high hum to a low boggy sound. Before I could find a place to pull over the cylinders stopped firing and the car died. I opened up the hood and one of the distributor wires was blown off the distributor. I replaced the distributor cap, wires, and distributor rotor button. Still wouldn't start after that. I pulled all the spark plugs and took out the fuel pump fues to check and see if I flooded it and no fuel came out of the cylinders. Anyways the engine will turn over but I am not getting any combustion. I tried to push start it and it sounded real boggy and would just die. Any help would be much appreciated. My car is a 2000 honda civic
Old Mar 28, 2012
BlueEM2's Avatar
Whachya lookin at?
Re: Alright I need help
Your timing belt broke
Old Mar 28, 2012
KenL's Avatar
Thanks for getting back to me, so quick. What do you think are the odds that I damaged the engine because of that.
Old Mar 28, 2012
BlueEM2's Avatar
Whachya lookin at?
If the timing belt did break its about 90% chance there is internal damage to the head. Maybe about 30 % chance damage to the pistons. You need to remove the valve cover and then the upper timing belt cover to see if the belt is still intact. Usually when a car dies in the manner that yours did it's a timing belt problem. When is the last time you replaced it?
Old Mar 28, 2012
KenL's Avatar
I have never replaced it. I just bought it used with 97,000 miles on it two months ago. I guess the person before me didn't replace it at 60,000 mile. I was checking prices and it looks like that would cost me about 2500 bucks. I might just be better off buying a rebuilt engine for 4k?
Old Mar 28, 2012
BlueEM2's Avatar
Whachya lookin at?
Buy an engine at a junkyard and rebuild it... An engine is probably about 5-700 an about 1500 to redo the gaskets and such. First, confirm the timing belt is the problem.
Old Mar 28, 2012
KenL's Avatar
Alright, thanks for all your help my friend. I really do appreciate it.
Old Mar 28, 2012
MindBomber's Avatar
Live for the Twisties
I wouldn't even bother with doing a rebuild, unless you plan on keeping the car for a very long time, just try to find something with low miles. $500 for an engine, $250 for a new timing belt/water pump/tensioner., $500 for labor swap it.
Old Mar 29, 2012
BlueEM2's Avatar
Whachya lookin at?
^ Yea sorry I didn't mean a full rebuild. I mean remove the head replace the head gasket/resurface and check the head. Timing belt, water pump, seals etc. I guess all that doesn't cost 1500 !
Old Jun 11, 2012
KenL's Avatar
Alright I got it fixed. It wasn't the timing belt. I opened up the oil port while I had someone start the car and noticed the lifters moving up and down and came to the conclusion that my timing belt was fine. Started thinking for a minute and realized that when I blew that plug wire I could have overloaded the ignition coil. Took the coil out and sure enough it was burnt out. Replaced that for 23 bucks and it's running fine now.
Tyler93
Detailing
Oct 24, 2015 09:48 PM
NROD315
Sep 4, 2015 09:22 PM
Brandon Vlasak
Jul 25, 2015 07:25 PM
hondadriver95
Jul 13, 2015 09:43 PM
jordan1794
Jun 11, 2015 09:14 PM
