Check Engine Light: O2 Sensor
Old Mar 23, 2012
x3nzox's Avatar
x3nzox is an unknown quantity at this point
Car: 1998 Civic EX
190,000 miles
2nd owner
I have the codes PO137, PO138, PO139, and PO325 when i went to Autozone and got it checked. Previously I only had the 02 sensor problem and now they said I have the Knock sensor problem... Where should I begin?
Old Mar 26, 2012
x3nzox's Avatar
Re: Check Engine Light: O2 Sensor
Bump
Old Mar 27, 2012
x3nzox's Avatar
bump
Old Apr 4, 2012
x3nzox's Avatar
Any1?
Old Apr 17, 2012
x3nzox's Avatar
Originally Posted by x3nzox
Any1?
Bump
Old Jun 4, 2012
Nardis's Avatar
Nardis is an unknown quantity at this point
...well I'd replace the O2 sensor first if you have that code, should be an easy fix
Old Jun 4, 2012
palsana's Avatar
palsana is an unknown quantity at this point
Make sure which O2 sensor you need? upstream or downstream.
Crazygrlinak
Oct 8, 2015 05:06 PM
sesi
Oct 1, 2015 02:03 PM
Le Ormz
Sep 30, 2015 09:24 AM
Luluharp
Sep 27, 2015 11:56 AM
