Sticky Throttle - '98 Civic DX
Old 02-19-2012
lgs 98dx's Avatar
lgs 98dx is an unknown quantity at this point
The throttle response is sticky for lack of better description as you give it throttle
Not 100% but most of the time
More noticeable when driving in town stop light to stop light
When it is sticky it makes it very difficult to feather the throttle past the sticking point. Which makes for an interesting take off
I have already cleaned the throttle body throat & butterfly valve of any carbon build up, but it didn't help
The IAC valve was replaced 15k ago with a NAPA unit (should have bought Honda OEM i guess), but uncertain if that has anything to do with this problem
A friend gave me a used complete intake manifold & throttle body assembly and suggested that I try swapping the throttle body & IAC valve assemblies
Worth a try or not?
Any other suggestions ?
Thanks
Lg
Old 02-19-2012
Re: Sticky Throttle - '98 Civic DX
Use your fingers. On YOUR throttle body. Does it stick?
If it works fine with your fingers but not with the pedal, then its the cable or pedal, and I haven't ever seen any problems with the pedals.
If it sticks when using your fingers, then either
it still has carbon causing the butterfly to hang closed,
someone jacked the throttle stop and it is hanging up in the bore,
or the shaft bushings are worn.
Old 02-22-2012
lgs 98dx's Avatar
I will do as you suggested and report back
Thanks
Old 02-23-2012
lgs 98dx's Avatar
I checked everything out tonight and found that there was excessive slack in the throttle cable where it attaches to the throttle body
All other items seemed good
Just guessing that when previous owner replaced the IAC valve he left too much slack
So, I adjusted the slack out and had no issues on my test drive
Old 02-23-2012
There is suopposed to be SOME slack. You don't want any chance of the cable holding the throttle open when your foot is off of the gas pedal.
Old 02-24-2012
lgs 98dx's Avatar
I left a tad of slack in the cable and the butterfly is definitely closed against the stop
Now the cable goes tight just before opening the butterfly
Before I took out the slack the cable had a noticeable droop & slack and it took a quite a bit before the cable tightened enough to open the butterfly
Does this sound ok?
Thanks
Old 02-24-2012
Sure.
I guess what really matters is that the throttle goes wide open when the gas pedal is mashed to the floor, without trying to stretch the cable out to do it.
If there isn't enough slack when the throttle is closed, then the cable will get stretched when the pedal is floored. Make sense?
Old 02-28-2012
lgs 98dx's Avatar
Sure.
Makes total sense
I will double checked the cable with pedal to the floor just to make sure
Thanks
tylerginevan
04-27-2015 12:29 PM
tkcne
04-18-2015 02:33 AM
Gunner
Engine DIY
10-06-2012 12:37 PM
jonavin
73
10-04-2004 07:18 PM
Quick Reply: Sticky Throttle - '98 Civic DX
