2000 Civic EX TONS OF PROBLEMS!
Old Nov 22, 2011
BrokenCivic4884's Avatar
BrokenCivic4884 is an unknown quantity at this point
Problem #1:
Radiator busted. Replaced radiator.
Problem #2:
Still overheating. Replaced thermostat.
*Cooling system problems fixed-no longer having issues with Problems 1, 2*
Problem #3:
Car stalling out periodically. Usually driving the car while it stalls. It's stalled driving forward, in reverse, turning left, etc.
The car was behaving like a manual transmission, stalling in idle as if I didn't hold a clutch down to switch gears. Usually pulling off from a stop, I can feel the car starting to struggle, if I press the accelerator, the car stalls out completely. I am able to restart it, no problem.
At least I got the car back home.
-Replaced fuel filter.
-Used a bottle of fuel treatment to evaporate any possible water in the fuel
-Still stalling.
Problem #4:
Now the car won't even start. The engine is turning over, it just won't start. The car has a brand new battery, everything inside the car turns on-lights, radio, etc.
I'm at a loss.
Any feedback is greatly appreciated!!!
Old Nov 22, 2011
MelJ's Avatar
Trance Addict
Re: 2000 Civic EX TONS OF PROBLEMS!
Are there any codes? Have you checked your fuel injectors and fuel pump(testing)?
Old Nov 22, 2011
dailydriverEX's Avatar
dailydriverEX is an unknown quantity at this point
Loose plugs or wires. Check them.
Old Nov 28, 2011
We replaced a rotor button and everything is working wonderfully!
Thanks for the input.
I can't take any credit, my boyfriend just decided it was worth replacing because he had a similar problem with one of his old trucks.
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
