CEL Light- Catalytic COnvertor
Old Sep 11, 2011
nickrolando's Avatar
nickrolando is an unknown quantity at this point
2000 Civic EX 4 door
Need a catalytic convertor, car has 210,000 miles on it so i'm trying to put as little as money as possible into it.
I want to get an aftermarket direct-fit c/c.
http://www.ebay.com/sch/i.html?Make=...=p3286.c0.m282
Does anyone know which one would be a complete direct-fit for my 2000 civic EX 1.6L 4 door
Thanks so much!
Old Sep 11, 2011
lazlong's Avatar
Re: CEL Light- Catalytic COnvertor
If you have to pass emissions then you're better off biting the bullet and getting the OEM.
number 4: http://www.hondapartscheap.com/south...t=0&quantity=0
If not, pretty much any of the inline ones will work (kinda). Not the manifold/converter style. The reason those are so cheap is 'cause they have a lot less precious metals in them, hence they don't work near as well.
Or, you could hollow the one you have out and do the O2 sensor trick: https://www.civicforums.com/forums/2...on-w-pics.html That trick will also work if you do straight pipe or if the cheap eBay cat isn't doing the job.
It's a good idea to have new bolts on hand 'cause chances are you're gonna have to cut the bolts off, especially with 200K+ on it. Also, hit the bolts with penetrating oil the night before you work on it just in case they will come out with a wrench.
Chances are you need new O2 sensors too. If you're still getting the code after cat replacement try new sensors.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
jdh022764
18
Nov 3, 2015 06:44 AM
Luluharp
Sep 27, 2015 11:56 AM
Mannimarco
Sep 7, 2015 10:01 PM
