Magnaflow exhaust sound
Old Aug 24, 2011
tkdcoop's Avatar
tkdcoop is an unknown quantity at this point
Hello, I have a 97 civic ex coupe and just installed a magnaflow 15646 cat-back system on my car and it is too loud. I have a drop in k&n filter and a pace-setter high flow cat in my car, otherwise stock. At idle the sound is fine, but going down the road I get a wicked reverberation off of the exhaust that rattles the inside of the car and is extremely loud. Is there anything that I can do to quite it down a little? (obvious answer is go back to stock) I don't mind a little noise, but this is nuts. I researched exhaust systems and read reviews prior to buying this cat-back and this was said to be a quite aftermarket exhaust! It is the 2.25" tubing btw. Any help or suggestions, is this normal for an aftermarket exhaust? Thanks.
Old Aug 24, 2011
robtec88's Avatar
robtec88 is an unknown quantity at this point
Re: Magnaflow exhaust sound
Make sure you have the all hanger points of the system isolated properly from the body. Any direct contact of the exhaust to the underbody will cause a lot of noise to transfer inside the car but may not necessarily sound loud outside of the vehicle.
Cheers!
Old Aug 25, 2011
tkdcoop's Avatar
Well I took it to the shop to have them check to make sure all bolts were still tight and they said that they slid my slotted pipe about a 1/2" further together and clamped down the u-bolt. That seems to have helped with quite a bit of the reverberation! I must have not had that joint fully sealed and was getting a lot of noise exiting through there before it hit the muffler...plus that joint is right behind the drivers seat. I have only had a chance to drive it a couple of blocks from the shop, I will update when I drive it on the highway if it is still too loud, thanks.
15EXCoupe
Jul 30, 2015 12:59 PM
Misfit2613
Jul 30, 2015 09:49 AM
S1N7H3T1C
Jul 21, 2015 05:20 AM
hayden55
Jul 8, 2015 11:38 PM
fvckbg
Jul 7, 2015 07:08 PM
