Blower does not work
Old Jul 27, 2011
P-rod's Avatar
P-rod is an unknown quantity at this point
Hello all.
I have a 98 Civic LX. Recently my blower stopped working at all levels. No air blowing out of the vents at all. The AC does work, but again, no air blowing at any setting.
Then, after a few days, the blower started working again, and each level 1-4 worked fine.
A couple of days after that, when I went to start the car, the blower stopped working again.
This time after a day of no blowing, I removed the blower motor to try to test the motor. But before I actually unplugged it, I turn the ignition on and it was working, so I just reinstalled it.
Now today, one day later, it stopped working again. Is it the motor, the resistor, the control switch, ?? or something else.
Thanks for any help.
Old Jul 27, 2011
Re: Blower does not work
usually the resistor is the first to go
Old Jul 27, 2011
P-rod's Avatar
I thought I read that if the resistor was not good, it would still work on high speed? I may have misread that, but thanks.
Old Jul 27, 2011
well first you should take the blower out and test it directly connecting to power and ground. if it comes on, its prolly fine. may also want to open it up and blow all the dust and dirt out.
Old Jul 27, 2011
P-rod's Avatar
When I removed it yesterday, I cleaned it as well as I could.
Can it be the resistor if it does not blow at all?
What about the control switch? If I turned the car off at high blow and restarted the car, still in high blow, would the switch still be open on high? Or does the switch work differntly than that?
Old Jul 27, 2011
the fan switch controls the blower speed. and it should stay wherever you put it when turning the car back on. technically a bad resistor would still allow the fan to work on max speed, but not always.
Old Aug 5, 2011
Stock 99's Avatar
I had a problem like that and it wasn't the resistor. The switch needed to be taken apart and the contacts cleaned. I just sprayed WD40 in the switch and it's been fine ever since.
mikemc422
Aug 9, 2018 05:41 PM
werdnahall
May 17, 2015 11:37 AM
ORskier
May 3, 2015 12:54 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
prowl
Apr 18, 2015 07:50 PM
