Radiator Fan question
Old Jul 8, 2011
bmboll's Avatar
bmboll is an unknown quantity at this point
I recently got a 97 Civic and noticed that the radiator fan isn't coming on. I checked the voltage on the fan plug located next to the radiator overflow reservoir. I got nothing. Is there supposed to be constant power to that plug? If so where should I go from here?
Old Jul 20, 2011
98EKCoupe's Avatar
98EKCoupe is an unknown quantity at this point
Re: Radiator Fan question
no the fan is switched by the PCM on the power side, voltage will only be present when the fan is commanded on by the computer, start with basics checking the fuse and the relay, also hook a test lamp at the radiator fan connector ground and battery positive to check for a good ground, if the test lamp illuminates your ground is good. if all that checks out it could be a bad pcm, broken wire between the pcm or a bad fan motor. if you could get your hands on scanner that performs bi-directional tests that would be ideal to see if you can manually command the fan on
aultman1990
Jun 20, 2015 09:12 PM
Bruce.Ringler
Jun 18, 2015 08:12 AM
Lunar
May 22, 2015 07:43 AM
hokiedad4
May 3, 2015 10:06 PM
prowl
Apr 18, 2015 07:50 PM
