99 Civic AC Expansion valve..
Old Jun 3, 2011
Dizz's Avatar
Dizz is an unknown quantity at this point
replacement.Has anyone done this&know how much of a job it is?also must this also be replaced with a new compressor&dryer,I know it is reccomended,but must it be done?Looking in my Haynes manual,it looks like a bear.
I`m installing a rebuilt tranny,&clutch kit,cv joint shafts&I`ve got my work cut out for me!
Regards,Dizz
Old Jun 4, 2011
lazlong's Avatar
Re: 99 Civic AC Expansion valve..
It's kind of a bear but, not too bad considering your obvious skillz. If your compressor went out then, yes, you need to replace it as well. It's one of the places the metal bits from the compressor end up.
Old Jun 4, 2011
Dizz's Avatar
I Thought That`s..what someone would say!When I 1st put a compressor on 2yrs ago,I could hear air trying to get thru expansion valve in dash(original comp locked up& 176K),but after a couple weeks the sound left&it`s worked great.The system with the rebuilt compressor has needed a little gas each year,when under the car removing the tranny,I say the slight oil leak aroung clutch pulley,so if oil leaking,then the gas is also leaking there.
Although the valve needed replaced with the comp(I did replace dryer),I can`t see how that would make the front seal leak,I would have expected a internal failure from floating junk,or reduced cooling.I`ve always felt the 6th gen AC`s to be on the weak side,it takes a while&recirc cabin air in hot weather,and that`s how it`s been since new.
Anyway,Thank`s,Dizz
Old Jun 4, 2011
lazlong's Avatar
I've heard that Hondas in generally really didn't have hardy A/C until recently.
Old Jun 5, 2011
JackedByJack's Avatar
JackedByJack is an unknown quantity at this point
yeah my ac is **** too
Old Jun 7, 2011
Dizz's Avatar
true,Civic Ac`s are weak.I a new 93,used 94,and this 99.The 99 is a little better than the 5th gen,but not much.Plan on re-circ in humid weather,where as a Cavalier is much better,at least for the AC!
Maybe not very hot in Japan?
I have found them to last for many years,though.LOL
Regards,Dizz
(I`m gonna try it with the old valve,1st.I`m tired of crawling under this car,for now!)
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
Lightman
Nov 10, 2001 06:44 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
