Help!!! Problems with 3rd spark plug wire!!!
I recently changed spark plugs and used the Bosch +4 plugs and also swapped out the wires which are Bosch as well. However I am still having trouble with the 3rd spark plug wire from the left still coming out of the engine block. I will push it down and it secures in place, then when I reach my destination whether it may be 1 mile or 20 miles away it is back out again. Could this be a piston or internal issue? check engine light not on.
I have checked the plugs and wire numerous times and both are still in good shape and intact. I have noticed oil around the ride side of the engine block and i've noticed a black streak on the hood underneath. I have noticed that it lags now when i shift into the next gear and noticed decreased feul mileage
I also haven't changed the pcv valve nor the fuel filter in a while - could this contribute in any way?
thana
Jun 15, 2020 07:05 PM
Wild Cranker
427
Jan 28, 2016 06:49 PM
danace99
23
Jun 28, 2015 08:49 AM
