My engine idles at 4000 rpm
Old Apr 16, 2011
zazspaz's Avatar
zazspaz is an unknown quantity at this point
I have a 98 civic with a single overhead cam non vtec. when I unplug the map sensor the idle drops to 2000 rpm. I have no check engine light on and can not figure it out.Anyone have any ideas?
thanks
Old Apr 16, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: My engine idles at 4000 rpm
4000rpms and no check engine light? Holy crap batman. Check your throttle cable and make sure its not too tight.
Old Apr 16, 2011
lazlong's Avatar
Does it stay high and not waver much or does it "search" for idle? 2000rpm is still way high, it should be at 700-800rpm for idle. Like tbohar said check the throttle cable. Also check for a vacuum leak. Put a scanner on it anyways, Autozone will do it for free.
Old Apr 16, 2011
zazspaz's Avatar
throttle cable is disconected
Old Apr 16, 2011
MelJ's Avatar
Trance Addict
Checked all your vacuum lines to make sure they're all connected? Although 4000 seems much much higher than I'd expect to see if there was a disconnected line. What's even crazier is no CEL
Old Apr 16, 2011
BlueEM2's Avatar
Whachya lookin at?
Yea everything other than the throttle cable SHOULD throw a CEL... That being said, make sure the throttle lever is free and not stuck... lube it up if necessary and clean it off with throttle body cleaner... After that I dont know... could be your TPS sensor, but again that should throw a code.
beneditti
Jan 15, 2016 12:31 PM
Ninetyatecivic
May 9, 2015 07:48 PM
lildoo
May 9, 2015 09:44 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
TaiChi
Dec 17, 2001 09:09 PM
