97 Civic no fire please help.
Old Apr 12, 2011
rab774's Avatar
rab774 is an unknown quantity at this point
I have a 97 EX civic it started missing and lost power at high RPM's . Then wouldn't start at all.I have changed the cap,rotor,button,plug's and even the distributor igniter and it still will not start.It has fire when you first turn it over and then it loses it.The distributor is still turning but only get fire for like one rotation.please help.
Old Apr 12, 2011
rab774's Avatar
Re: 97 Civic no fire please help.
Problem solved it was the ignition coil.
Old Apr 15, 2011
SAMURAI GECKO's Avatar
SAMURAI GECKO is an unknown quantity at this point
i have a 97 hx that just quit one day on the highway. i had it towed home and after many hours of searching found that on the pass. side fuse box under the hood there was a blown 40amp ignition fuse. it was a wierd looking fuse that has two copper tabs that screw it down and a green box with a clear top in between the tabs. i soldered it back together and the car started right up. so i threw out that fuse and ordered a new one and no problems since. but mine wouldnt turn over at all. not like yours seems to... but its something to look into...
Old Apr 15, 2011
well i read your other post (which i should have done in the first place) and see you fixed it so i guess ignore my post!!!! thanks
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
cdt12271
Apr 23, 2015 11:36 AM
Blaster30
Apr 22, 2015 12:21 PM
AlexLx
Nov 7, 2001 10:09 PM
