Anyone Care For a Civic Survey?
Old Mar 29, 2011
Dizz's Avatar
Dizz is an unknown quantity at this point
1. Year Model
2.Milage
3.What Brand of oil&how often changed
4.Type driving,highway,2 lane etc
5.Are we the type that runs the crap out of it,or more old man type
6.Other than regular maint,what type of major repairs
7.Any other type of warts,trouble spots(wheel bearings,transmission bearings,sync,etc.)
8.Any special oil addatives,Seafoam etc.
I think this imfo would be usefull,maybe others as well.
Regards,Dizz
Old Mar 29, 2011
Dizz's Avatar
Re: Anyone Care For a Civic Survey?
mine is a 99 Civic DX,5 speed
243K
Tech Walmart oil,every 3-4K changed
Mountain driving
I run the crap out of it,don`t abuse,but I rev to the red line a couple times a week,to pass trucks,and have slowed some since gas hit $3.I ran it for 3yrs off road 10 miles a day in the mud,and have dented up floor boards dragging in rocks&mud,and go places to bowhunt I shouldn`t.
At 196K,new piston rings&head job(head gasked blew,needed timing belt,so I did rings,turned out good)(Honda parts)
Problems with front wheel bearings,about 5 new bearings,and have some tranny bearing noise,that dosen`t seem to getting worse,I guess to be expected with high milage .I still have original clutch,CV joints,struts,tie rod ends,and fuel filter.
I use Seafoam part in breather,rest in gas,2 times a year
Dizz
Old Mar 29, 2011
MindBomber's Avatar
Live for the Twisties
1. 2002 Canadian Si
2. 145,000 kilometers
3. Royal Purple, changed every 6000km, hamp filters.
4. 70/30 -highway/city split
5. I drive aggressively, but not abusively.
6. Outside out maintenance I've never needed to repair anything.
7. The transmission slips when cold, but with regular atf changes the problem plateaued.
8. None.
Old Mar 29, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
1. 2000 honda civic si
2.bought used 2007 at 79k now at 136k
3.royal purple in the summer, then mobile one syntech every 4-6k miles
4.everyday highway slowest i drive is 55 then top out at 120 every sunday, 85-90 mid week
5.8k redline once in a while in northeast you gota drive aggrressive cuz ******* likes to cut you off.
6.replace rack and pinion, clutch and flywheel, shock struts
7.bent radiator support, tranny makes loud rattle noise 3rd gear grind when shift hard.
8.so far i used fuel injector cleaner
Old Mar 29, 2011
MelJ's Avatar
Trance Addict
1. 2000 Civic Si
2. About 138,5xx
3. Started with Mobil 1, recently switched to Valvoline Max Life Syn Blend for cost reasons.
4. I'm in between, but a majority is spent on the highway and backroads between maybe 45-70 mph. I do get on it once in a while though just to put a grin on my face.
5. I drive pretty calmly. I'm not an aggressive driver by any means.
6. Major repairs. Um. I replaced my fuel filter with an aftermarket one and now the car won't start, so I need to check into that. Ran for a week. I hope it isn't my fuel pump. We'll find out tonight I guess. I also replaced my CV Axles and sway bar end links, and outer tie rod ends. Other than that, nothing out of regular maintenance.
7. Besides the extra stuff I've replaced, nothing.
8. Only additives I've used are gas line antifreeze and fuel system cleaner.
Old Mar 29, 2011
Steven21's Avatar
Steven21 is an unknown quantity at this point
1. 99 Honda civic vp
2. 121k
3. Valvoline maxlife every 3- 4.5k
4. 80/20 highway to city and the people here are insane so i push 110 regularly about once a week
5. I try and drive calmly but i end up pushing it pretty hard
6. Have the entire front end off a 99 Si. Car was wrecked within a year of being made and had the front end rebuilt.
7. I have the worst exhaust ever and big dent in the rear quarter panel i got by leaning on the car....
8. Fuel injector cleaner
Old Mar 29, 2011
Kennykid2002's Avatar
Kenny the Ricer
1. 2003 EX Coupe
2. 64500
3. Mobil 1, Changed about every 5k miles, or 3 months (Whichever comes first)
4. Mostly highway miles racked up.
5. 50/50 Sometimes relaxed, sometimes aggressive. Depends on my mood
6. No major repairs done to the vic, cept an oil pan change
7. Minor things, like window motor, lock actuators
8. No additives, ever
Old Mar 29, 2011
specialized7's Avatar
specialized7 is an unknown quantity at this point
1. 2002 Canadian SI
2. 220 000 Kilometers
3. 5w20 Mobil 1 every 5 K
4.All City
5.Open her up once in a while
6.Front Struts since iv had it
7.Wont go into reverse all the time
8.No additvies
Old Mar 29, 2011
1. 2002 civic EX auto
2.98,000 miles
3.Full synthetic 5w30 (redline, penzoil ultra, etc) every 10K
4.95% city, 5% highway
5.moderate driving, but mostly below 4k rpms
6.alternator, head gasket, bushings, suspension parts, etc
7.auto trans slips and about to fail soon
8.lubecontrol.com lc20 in oil (engine, trans, ps) and fp-plus in gas
Old Mar 29, 2011
Originally Posted by Dizz
1. Year Model
2.Milage
Regards,Dizz
i think u should add #9 current pic of the car, as it age we all wanna see how well our car could withstand everyday driving
Old Mar 30, 2011
Dizz's Avatar
pictures,or more imfo would be fine with me.I don`t care much about how it looks,it gets me to work across some of the worst roads in WV,and is basic transportation point A to B for me,but i`m sure different for some of the rest of you.My wife has a 07 Accord that`s pretty!
Old Mar 30, 2011
Dizz's Avatar
2.98,000 miles
Not sure I did this right,trying to reply to you,but I think head gaskets,and minor oil burning is standard for these after 100K
Regards,Dizz
Old Mar 30, 2011
BlueEM2's Avatar
Whachya lookin at?
1. 2005 EX manual
2. 110,000
3. Whatever type of synthetic blend is on sale every 7.5k miles
4. Highway at 75MPH
5. I beat the CRAP out of my civic every time I drive it and I have since new... but she still loves me and always will.
6. Head gasket caused by thermostat failure undetected by idiot (me)
7. Need ball joints... wheel bearings... that's about it
8. Nope, no additives at all... runs like a top, even with me driving it
Old Mar 30, 2011
MindBomber's Avatar
Originally Posted by tbohar
1. 2005 EX manual
2. 110,000
4. Highway at 75MPH
Old Mar 30, 2011
1. 02 EX coupe manual
2. 87k miles
3. Mobil1 last time, usually 4-6k miles
4. short drives last year, mix city/highway when back to US, autoX regularly when in US, track days twice a year?
5. old man, but drive 70% of capabilities of car in streets (never above it) and race it on track and autoX..
6. rebuilt trans, axles replaced, SRS siemens module replaced, both front LCA's.
7. Need a more powerful engine
8. No
Mods:
Eibach pro springs
KYB AGX dampers
Progress rear sway bar
Skunk2 rear camber kit
front ingall camber bolt (soon to be top camber plates)
(lack of the last 3 are the ones that killed my trans and axles - too much understeer and wheel spin on cornering - potentially killed the engine mounts and the LAC compliance bushings as well - LCA were cracked - potentially same reason? always get camber kits, gents.) The lat 3 did correct behaviour and now counter-steer in corners.
Front neuspeed strut bars - good for a better feel of the steering - no performance gains.
Muffler - just got it so the pipes don't hit the meaty rear sway bar
AEM CAI - just sucks water when rain season comes... HP gains?!? bwaaahahaha!
Dumb projector headlights, but still better than the stock beaten ones. DRL to pass canada inspections wired to the halos - will disconnect when get back to US.
Graphite in the door locks everytime it starts to freeze.
Blushing of the door power locks everytime the snow that melted in the door (have to pass the badge in the gate when leaving work, right?) seeps in and freeze the power lock, so nothing opens. (darn!)
Old Apr 4, 2011
Dizz's Avatar
Surely Some people out there with really high milage&some major engine overhauls??Maybe 300-400K?
Guess not,
Dizz
CarStuff
Dec 6, 2020 12:52 PM
ChristinaVHH
May 10, 2015 03:51 PM
bsmiley
Apr 27, 2015 01:27 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
