'97 Civic DX, power doors don't work.
Old Mar 15, 2011
ckeboss's Avatar
ckeboss is an unknown quantity at this point
Ok, so I just bought a '97 DX as my first car, and I believe it has power locks. When I click the keyfob, I can hear a fait "click", but not from the doors. The little red light flashes off for a second when this happens. Any idea what is wrong?
Old Mar 15, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
Re: '97 Civic DX, power doors don't work.
that click u hear is from the relay coming from the keyless entry module
does ur car have the power lock button on the door inside
Old Mar 15, 2011
ckeboss's Avatar
Nope. Only buttons are on the keyfob.
EDIT: It also says TRC on the keyfob. Is it stock, or aftermarket?
Old Mar 15, 2011
aftermarket
u probly need to install power locks motor on the door
and connect it with the alarm unit
Old Mar 15, 2011
ckeboss's Avatar
So the previous owner you think installed the unit without the actuators? Is there perhaps a fuse blown, or should I open up the side panels and check it out?
Old Mar 16, 2011
open the side panel and find out if theres a fuse blown
its most unlikley to even have a blown fuse
then check for the acuators and work your way from there
Old Mar 16, 2011
ckeboss's Avatar
Ok. Any good tutorial for taking the door side panels off on a 97 DX?
Old Mar 16, 2011
check for screws if i remember correctly theres like 4 screws
as u remove the speaker grill theres 2 screws
one on the pocket and one at the lock lever where u pulled to open the door
then u pop the panel with a flat head
Old Mar 18, 2011
ckeboss's Avatar
Ok. I ordered a door panel remover tool to get clips out. Will be here tomorrow. Will try to take it off and see what's up in there. Will update here with pictures.
Old Mar 18, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
door panel clip tool? thats what your hands are for and a wide blade plastic scraper, lol tool for the clips.
Old Mar 18, 2011
those clip will break due to age and moist
regardless if you try to be careful
the price you pay for the clip tool removal?
never thought that exist
but anyway u can buy all new clips from any auto store
even ebay sells them like 20 for 3 bucks
i rather just buy new clips cuz they seem to hold more
if you remove all the screws
take a flat head screw driver and pop the panel from the bottom and work your way up
once you got all of the clips to unclip slide the panel up and off it comes
if its stubborn just stare at it, it will eventually fall off
Old Mar 19, 2011
ckeboss's Avatar
http://www.amazon.com/gp/product/B0017HX5DE
I can remove the door handle. That is the only visible screw I can see. I see that at the bottom, there is the speaker grill/place to put stuff that is a separate piece. I tried going around it, trying to pry it off. Don't want to break anything, but that thing is on there good. Should I just use a bit more force. I can post pictures of what I am talking about if you want.
Old Mar 20, 2011
the speaker grill you just pop it open
it wont break if u use a bit more force
Old Mar 20, 2011
nsxvtec's Avatar
nsxvtec will become famous soon enough
there are 2 or 3 screws behind the speaker/ grille that need to be removed as well as the screw that holds the door panel to the door. That one is at the armrest/ door pull area.
if you don't have power door lock switches on the doors then your car probably did not come with OEM power door locks.
Old Mar 21, 2011
ckeboss's Avatar
Ok. Got the panel off. It doesn't look to have any keyless entry system in the doors. Any idea what this aftermarket keyfob even is? Did someone just not finish the job? Thanks. Pictures below.
Old Mar 21, 2011
SO theres no lock solonoid then u only have a arm and disarm whiches alarm goes off when somone trys to open your door or hit your car
Old Mar 21, 2011
ckeboss's Avatar
How would I test the alarm to see if it even works? The red light stays on no matter what. Also, can you use the existing parts and add actuators to make it work?
Old Mar 21, 2011
arm it then try to open the door with the key
then try to start it and see wat happens
Old Mar 22, 2011
ckeboss's Avatar
How do I know if it's armed? It doesn't beep or react.
Old Mar 23, 2011
hit the lock button on the remote u should see the led light blink on picture 6 if it doesnt blink and the light stays on then the alarm is in valet mode, if so locate a switch thats underneath the driver dash or at the kick panel, if u found the switch turn on to ign2
do not start hit the switch then u should see the light doesnt stay on no more
then re arm the car
Old Mar 23, 2011
the power door locks we need to get to that later as of u need to know if the alarm is functional
Old Mar 23, 2011
ckeboss's Avatar
Ok. Found the switch and held it for a few seconds while in ign2. The red light turned off. Now I can arm it. Still don't know how to disarm it, as when I click the unlock button, it beeps 2x, but then the light remains on, and it goes off. So I just put it back into valet mode for now. So what would I need to see/buy to install aftermarket power locks?
Old Mar 23, 2011
when it beep twice its disarm when it beep once its arm
Old Mar 23, 2011
ckeboss's Avatar
Ok, so what would I need to see/buy to install aftermarket power locks?
Old Mar 23, 2011
http://cgi.ebay.com/ebaymotors/Remot...Q5fAccessories
i found this while i was surfing i hope it helps
u dont need the module u can connect the solonoids to ur exisiting alarm
if u locate ur module u see the diagram on the box where it says door locl and unlock
u can buy this and sell the module keep the solonoid but for 30 bucks for 4 solonoids and a module is cheap
Old Mar 23, 2011
or this
http://cgi.ebay.com/ebaymotors/POWER...item33658d6cad
Old Mar 23, 2011
ckeboss's Avatar
Ok, just bought the four solenoids kit. Will let you know when it gets here. I am only 65 miles away from them, so it should be here soon.
Sure I will have questions on how to install it into my existing alarm. Any good tutorials already made? I will make one on taking that door panel off, as it took me a while to figure out.
Old Mar 24, 2011
i have an extra alarm unit where it shows diagram so i can take a pic for you
once the solonoid gets there show me the wires and i show u how to wire them
im good with electronics just not good at installing them
Old Mar 26, 2011
ckeboss's Avatar
Package will be here on monday. Where exactly is the unit that these hook up to? How do I get to it?
Old Mar 28, 2011
Firearmor's Avatar
Firearmor is an unknown quantity at this point
Brother, i think you are getting into a project that your aren't going to like. My best suggestion is to remember that the car is a DX and the pain of locking and unlocking the doors by hand will probably be less then the pain of installing actuators that will become useless after that crappy key-less entry dies on you. Sorry, I don't mean to be a bum. I have just removed more aftermarket key-less entry's then i would like to think about.
