What is it
Old Mar 15, 2011
t4rboy's Avatar
t4rboy is an unknown quantity at this point
What is it
According to the FSM this is called the "VTEC solenoid." The part stores here have no idea what that is. I know that it is leaking oil and needs new gaskets but I cant get them until I have an idea of what its called. Its is on a 97 civic ex with the tec motor. it is located on the head near the intake passenger side. Does anyone know what it is and what it does?
Old Mar 15, 2011
Re: What is it
its the vtec solenoid. the top head piece is the actual solenoid, the bottom is the valve. they work as one unit but can be dismantled to change gaskets. i would just go thru honda for them. the lil sensor on the side is the oil pressure switch.
Old Mar 15, 2011
lazlong's Avatar
Re: What is it
#11 and #21: http://www.hondapartscheap.com/south...t=0&quantity=0
Old Mar 15, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: What is it
Never thought the solenoid gasket would ever need replacing...but meh
Just clean the filter while ur at it
Old Mar 15, 2011
Re: What is it
there are two rubber gaskets, and one has a built in wire screen which can clog or the gasket shrinks.
Old Mar 16, 2011
t4rboy's Avatar
Re: What is it
Thanks for the help with what it is now what does it do? I'm do all my own wrenching but mainly on toyota 4x4s. cars arn't my thing. I know all about oil pressure switches but why the vtec soleniod?
Old Mar 16, 2011
Re: What is it
they are part of the system that activates the v-tec (oil pressure, besides the electronic parts) - failure there will throw a engine check light.
Old Mar 16, 2011
lazlong's Avatar
Re: What is it
When the ECM/PCM reads WOT and oil pressure at a certain level it activates the solenoid and changes to the larger cam lobe. Basically it gives you about 15 more hp from about 3000rpm to about redline when you floor it.
Old Mar 16, 2011
Re: What is it
15 ponies?!?
Wow! It doubles the WHP?!?
Old Mar 17, 2011
t4rboy's Avatar
Re: What is it
So basically honda decidsed instead of doing a better grind on there cam they would make things more complicated
Old Mar 17, 2011
Re: What is it
EX is econo car, and actually have these 15 HP, much better than the lower trims.
The Si gets the real V-TEC but you pay for it too
