99si throwing P0106
Old Feb 13, 2011
22tango's Avatar
22tango is an unknown quantity at this point
99si throwing P0106
Hi guys,
I have a 1999 civic si turbo and yadda yadda all that jazz. I keep throwing P0106 and I want to say P0107 but i am at work and that car is at home so can't double check. But, does anybody have any ideas what an easy fix could be or where I should start. Haven't dealt with this one before. Thanks
Old Feb 13, 2011
lazlong's Avatar
Re: 99si throwing P0106
Possible causes of P0106:
- Bad MAP sensor
- Water/dirt intrusion affecting MAP sensor connector
- Open or short in the reference, ground, or signal wire for the MAP sensor
- Ground problem due to corrosion causing intermittent signal problem
- Bad PCM (do not assume the PCM is bad until you've exhausted all other possibilities)
Possible causes of P0107:
- Bad MAP sensor
- Open or short in the signal circuit or 5 volt reference circuit
- Ground circuit open or shorted
- Bad PCM
Best way to check reference voltage is with a scan tool in live data mode. Chances are the MAP sensor is bad although I would visually inspect the wires and connections first.
Old Feb 16, 2011
22tango's Avatar
Thanks for the info. I am also throwing p1106 and have 2 of the main symptoms from p0106, car backfires once in a while, blows black smoke out tail pipe with fast acceleration, as well as misses at speed sometimes. any thoughts?
Old Feb 16, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
P1106 Barometric Pressure (BARO) Sensor Circuit Range/Performance Problem
check this link for more info on it; http://honda-tech.com/showthread.php?t=2456684
Old Feb 17, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
hmm this is somthing strange and hope i wont run into this problem with my 00 si
for the black smoke when hitting vtec,mines does that too and i also seen it on mostly vtec engine, there was this one time my engine mifire at wot and stall in the middle of the highway, i nearly shitted myself, came to check it out the spark plug connector seized out where it connected to the distributor cap, hopefulyl somone know how to fix this issue
JetsterDajet
52
May 8, 2016 12:11 AM
Rlss
24
Feb 26, 2016 09:42 PM
Wariogamer
Sep 29, 2015 09:49 AM
2005seTO
Aug 30, 2015 10:32 PM
Kcpowerhouse
Aug 25, 2015 01:15 PM
