OBD II code problem
Old Jan 30, 2011
evil-lyn's Avatar
evil-lyn is an unknown quantity at this point
OBD II code problem
has 2 codes -- 1457 & 1457 pending has to do with EVAP what would cause this .... can faulty gas cap do it ? an what does the pending mean ?
Old Jan 30, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: OBD II code problem
These are realted to the function of the evap emissions system there are several causes but the easiest things to check are; Under the passenger side seat there is a 2 wire plug that goes through the carpet see if that plug is corroded or has been damaged you will need to remove the seat for this, also check the gasket on the gas cap see if its cracked and dried out, if it is then replace it.
sharp66
31
Jun 12, 2022 08:45 AM
EdGasket
May 26, 2015 06:19 PM
kevin99ek
Apr 23, 2015 09:32 PM
dooner24
Apr 14, 2015 07:51 PM
vtechin
Dec 25, 2001 03:24 PM
